How to deploy a gmf plugin? [message #147848] |
Sun, 26 August 2007 14:28 ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Originally posted by: jorge.matos_.-gmail.com
Sorry for this noob question, but I have a gmf plugin with the common 3
projects (xxx, xxx.diagram and xxx.edit) along with 2 more projects that I
need and I want to know how to deploy all these projects to a end user.
Thanks in advance.
Re: How to deploy a gmf plugin? [message #147856 is a reply to message #147848] |
Mon, 27 August 2007 08:41 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Originally posted by: mom.mom.gmx.net
Use export as "Deployable plugins and fragments". This creates a zip the
enduser has to extract and copy into the plugins dir.
If you have a website, it better to create a feature project, which
package your plugins togethern, and package these with a site project.
The site project can then be published as update site, so your enduser
has easy access to updates.
Rainer
> Thanks in advance.
Re: How to deploy a gmf plugin? [message #147926 is a reply to message #147856] |
Mon, 27 August 2007 14:14 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Thanks for your help!!
"Rainer Weinhold" <mom.mom@gmx.net> wrote in message
news:fau2p4$ap8$1@build.eclipse.org...
> Rainer
>> I
>> Thanks in advance.
Re: How to deploy a gmf plugin? [message #148746 is a reply to message #147856] |
Sun, 02 September 2007 02:53 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) |
Hello again!
I tried those steps but unfortunately after I unpacked the generated zip to
the Eclipse plugins folder and start the Eclipse I can't start a new project
of that plugin because the options isn't there...
Do I need anything else to deploy the plugin?
Thanks once again.
> Rainer
>> I
>> Thanks in advance.
FUDForum. Page generated in 0.03609 seconds
