Home » Newcomers » Newcomers » Spurious options listed under my Run button
Spurious options listed under my Run button [message #147561] Mon, 10 April 2006 05:13 Go to next message
Originally posted by: NoOne.Nowhere.net
Hi All,
The down-arrow adjacent to my Run button lists a spurious item I'd like to
eliminate: The name of a project who's directory I deleted before deleting
the project from Eclipse.
How can I do that?
I'm running Eclipse 3.1.2 over WinXP-Pro/SP2.
Richard
Re: Spurious options listed under my Run button [message #147586 is a reply to message #147561] Mon, 10 April 2006 07:57 Go to previous message
Olav Müller is currently offline Olav MüllerFriend
Am Mon, 10 Apr 2006 01:13:27 -0400 schrieb Richard Lionheart:
> How can I do that?
When you enter the "Run ..." Wizard (second from the bottom in the list it
should be) you can easily delete single run configurations from the menu.
Is this what you are looking for?
CU,
Olav
Previous Topic:Font size in left hand pane of help system
Next Topic:Internationalization
Current Time: Fri Dec 27 07:05:06 GMT 2024
Powered by FUDForum. Page generated in 1.23967 seconds
