eclipse birt [message #147504] |
Thu, 23 March 2006 16:21 |
Jan Kor Messages: 1 Registered: July 2009 |
Junior Member |
I am a new user of eclipse BIRT version 2.0.1. I am having trouble with
creating a JDBC datasource with DB2 driver. I followed the installation
procedure -
JDBC Drivers
You will likely want to use your own JDBC driver with BIRT. Use the data
source editors JDBC driver management wizard. To start the wizard, open a
BIRT report design, go to the Data Explorer view, right click on Data
Sources and select New Data Source. Choose JDBC Data Source and click
Next. In the next dialog, choose Manage Drivers
to bring up the
Manage JDBC Drivers dialog.
In the JAR Files tab, click on Add
to add the JAR file required by
your JDBC driver. Then go to the Driver tab to confirm that the list of
drivers includes the new drivers added. You may also want to assign a
display name and URL template for the new drivers in this tab.
However I am getting the following error whe I test connection -
Cannot create instance of JDBC Driver class COM.ibm.db2.jdbc.app.DB2Driver
I have added the db2java.zip in classpath. The database I am trying to
connect id DB2 version 7 on OS 390.
Please let me know if there is something I am missing. Any assistance in
the matter is welcome.
Thanks.
FUDForum. Page generated in 0.65500 seconds
