intel vtune's eclipse packages [message #147218] |
Wed, 22 June 2005 22:54 |
Originally posted by: blwang.dstmedia.com
I've installed intel's vtune performance analyzer and the related eclipse
packages. When I start eclipse, I got the following error message in my
metadata/.log:
!SESSION Jun 23, 2005 10:23:45.136
java.version=1.5.0_03
BootLoader constants: OS=linux, ARCH=x86, WS=gtk, NL=en_US
Command-line arguments: -os linux -ws gtk -arch x86 -install
file:/opt/intel/eclipse/
!ENTRY org.eclipse.ui.workbench 4 2 Jun 23, 2005 10:23:45.137
!MESSAGE Problems occurred when invoking code from plug-in:
"org.eclipse.ui.workbench".
!STACK 0
java.lang.UnsatisfiedLinkError: no idvcjni in java.library.path
at java.lang.ClassLoader.loadLibrary(Unknown Source)
at java.lang.Runtime.loadLibrary0(Unknown Source)
at java.lang.System.loadLibrary(Unknown Source)
at com.intel.vtune.idvclib.IDVCLibPlugin.<clinit>(IDVCLibPlugin.java:20)
at sun.reflect.NativeConstructorAccessorImpl.newInstance0(Nativ e Method)
at sun.reflect.NativeConstructorAccessorImpl.newInstance(Unknow n Source)
at sun.reflect.DelegatingConstructorAccessorImpl.newInstance(Un known
Source)
at java.lang.reflect.Constructor.newInstance(Unknown Source)
org.eclipse.core.internal.plugins.PluginDescriptor.internalD oPluginActivation(PluginDescriptor.java:722)
org.eclipse.core.internal.plugins.PluginDescriptor.doPluginA ctivation(PluginDescriptor.java:188)
org.eclipse.core.internal.plugins.PluginDescriptor.getPlugin (PluginDescriptor.java:306)
at org.eclipse.ui.internal.Workbench$15.run(Workbench.java:1325 )
org.eclipse.core.internal.runtime.InternalPlatform.run(Inter nalPlatform.java:1006)
at org.eclipse.core.runtime.Platform.run(Platform.java:413)
at org.eclipse.ui.internal.Workbench$14.run(Workbench.java:1334 )
at java.lang.Thread.run(Unknown Source)
!ENTRY org.eclipse.ui 4 4 Jun 23, 2005 10:23:45.139
!MESSAGE Unhandled Exception
!ENTRY org.eclipse.ui 4 0 Jun 23, 2005 10:23:45.140
!STACK 0
Source)
!ENTRY org.eclipse.ui 4 4 Jun 23, 2005 10:23:45.171
!MESSAGE Unhandled exception caught in event loop.
!ENTRY org.eclipse.ui 4 0 Jun 23, 2005 10:23:45.172
!MESSAGE Failed to execute runnable (java.lang.UnsatisfiedLinkError: no
EcGUIClientHandler in java.library.path)
!STACK 0
org.eclipse.swt.SWTException: Failed to execute runnable
(java.lang.UnsatisfiedLinkError: no EcGUIClientHandler in
java.library.path)
at org.eclipse.swt.SWT.error(SWT.java:2330)
org.eclipse.swt.widgets.Synchronizer.runAsyncMessages(Synchr onizer.java:101)
at org.eclipse.swt.widgets.Display.runAsyncMessages(Display.jav a:1824)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :1642)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.jav a:1402)
at org.eclipse.ui.internal.Workbench.run(Workbench.java:1385)
org.eclipse.core.internal.boot.InternalBootLoader.run(Intern alBootLoader.java:858)
at org.eclipse.core.boot.BootLoader.run(BootLoader.java:461)
at org.eclipse.core.launcher.Main.basicRun(Main.java:291)
at org.eclipse.core.launcher.Main.run(Main.java:747)
at org.eclipse.core.launcher.Main.main(Main.java:583)
!ENTRY org.eclipse.ui 4 4 Jun 23, 2005 10:23:45.174
!MESSAGE
*** Stack trace of contained exception ***
!ENTRY org.eclipse.ui 4 0 Jun 23, 2005 10:23:45.175
!MESSAGE no EcGUIClientHandler in java.library.path
!STACK 0
java.lang.UnsatisfiedLinkError: no EcGUIClientHandler in java.library.path
at com.intel.vtune.shell.ShellPlugin$1.run(ShellPlugin.java:250 )
at org.eclipse.swt.widgets.RunnableLock.run(RunnableLock.java:3 5)
org.eclipse.swt.widgets.Synchronizer.runAsyncMessages(Synchr onizer.java:98)
!SESSION
!ENTRY org.eclipse.core.launcher 4 0 Jun 23, 2005 10:23:49.292
!MESSAGE Exception launching the Eclipse Platform:
!STACK
java.lang.reflect.InvocationTargetException
Caused by: java.lang.reflect.InvocationTargetException
org.eclipse.core.internal.boot.InternalBootLoader.run(Intern alBootLoader.java:861)
... 7 more
Caused by: java.lang.UnsatisfiedLinkError: UnregisterWithShell
at com.intel.vtune.shell.ShellPlugin.UnregisterWithShell(Native Method)
at com.intel.vtune.shell.ShellPlugin.access$1100(ShellPlugin.ja va:53)
at com.intel.vtune.shell.ShellPlugin$3.run(ShellPlugin.java:322 )
at org.eclipse.swt.widgets.Display.release(Display.java:1694)
at org.eclipse.swt.graphics.Device.dispose(Device.java:172)
at org.eclipse.ui.internal.Workbench.run(Workbench.java:1390)
... 8 more
Any help will be appreciated.
FUDForum. Page generated in 0.02422 seconds
