JDK 1.5 [message #147095] |
Wed, 03 March 2004 02:16  |
Originally posted by: mehaut.xavier.free.fr
I would like to know when it is intended to provide a first release of
Eclipse with JDK1.5 (even beta) ?
regards
Xavier
Re: JDK 1.5 [message #147321 is a reply to message #147258] |
Thu, 04 March 2004 12:00   |
I agree totally with tom ; If JDK1.5 is available in very few months,
Eclipse should be also ready for it. In my opinion, many refactoring
enhancements or other features which are planned are very fine, but is
less important than havinf the IDE ready to use JDK1.5 when this one will
be available as release. I'm of ones who will use loop, generic, metadata,
autoboxing when it will be available, because these notions are missing
today.
regards
Xavier
> Eons ago, back in the stoneage when Java was new (JDK 1.01 -1.02)
> Visual Cafe was a powerful Java IDE. Many people used it, myself
> included. Then JDK 1.1 arrived with a new event model. Visual Cafe
> took over a year to get their compiler up to speed.
> I and many other were not willing to wait, so we dumped Cafe. I went
> to Kawa (now defunct) because it directly supported whatever JDK I
> wanted to use.
> I love Eclipse. It's by far the best IDE I've seen. However, I am
> concerned with the discussions about how much effort and time it will
> take to get support for 1.5.
> If it takes very long, many users will likely find it necessary to
> look elsewhere for an IDE the provides the language support they
> require.
> JMO.
> On Thu, 4 Mar 2004 12:14:51 +0100, "Philippe Mulet"
> <philippe_mulet@fr.ibm.com> wrote:
> >Please also check the following bug report which contains some update on
> >this front:
> >https://bugs.eclipse.org/bugs/show_bug.cgi?id=36938
> >"xavier" <mehaut.xavier@free.fr> wrote in message
> >news:c241b9$p59$1@eclipse.org...
> >> I'va found another thread about this subject ;)
> http://www.eclipse.org/newsportal/article.php?id=7316&gr oup=eclipse.tools.jdt
> >> > Hello,
> >> > regards
> >> > Xavier
Re: JDK 1.5 [message #147359 is a reply to message #147258] |
Thu, 04 March 2004 18:06   |
One of the difficulties in adding 1.5 support to eclipse is that the
language specification
is not yet complete, and sometimes running "javac" is the only reference.
For example, the JLS proposal for autoboxing does not specify the
process of disambiguating
overloaded method calls. The generics document is quite old, and even if
it describes method
disambiguation, you know nothing about how that works together with
autoboxing.
I agree that JDK 1.5 support should be top priority, but it looks like
it isn't that simple ...
Genady
>wanted to use.
>require.
>JMO.
>>this front:
>>>>Hello,
>>>>regards
>>>>Xavier
Genady Beryozkin
http://www.genady.net/
Re: JDK 1.5 [message #147446 is a reply to message #147258] |
Fri, 05 March 2004 08:01   |
I've written about this before but I can't resist writing again to support
Tom
and urge that 1.5 support be given a very high priority and that every
effort be made to include it in 3.0. Unfortunately, there is a free
competitor
for Eclipse that will support 1.5. Its called netbeans and it comes from
Sun.
I too am a very happy, dedicated Eclipse user and I dread the thought of
switching. Still, if 3.0 comes out without 1.5 support, I'll have to look at
that option very closely.
Java 1.5 is available now so please don't use that as an excuse. I know
its in beta but the basics of the new language features are VERY unlikely
to change.
One more point. If the choice is releasing 3.0 on schedule without 1.5
support or delaying A LITTLE BIT and releasing it with 1.5 support,
I'd vote for the latter. The latest milestone release could be used in the
meantime.
Steve Buroff
"Tom" <tcrosman@wapa.gov> wrote in message
news:bkce40h35j6m43frm92m7rgnm9f2mjsvqs@4ax.com...
> wanted to use.
> require.
> JMO.
> >this front:
dt
> >> > Hello,
of
> >> > regards
> >> > Xavier
Re: JDK 1.5 [message #156278 is a reply to message #156112] |
Wed, 28 April 2004 05:27  |
Originally posted by: wagner.stefan.berlin.de
Hi Philippe,
> Did you miss the post about JDT update for J2SE1.5 : Cheetah04 available ?
> Look a few frames below.
Yes - I visited the eclipse - website and didn't find anything.
I didn't thought it could be somehow hidden.
Now I found it but it doesn't plug into my M8 2004-03-26 15:17
Do I need a newer version?
Is it true, that I shouldn't run eclipse on a j2sdk-1.5 itself?
Re: JDK 1.5 [message #156287 is a reply to message #156278] |
Wed, 28 April 2004 02:58  |
Yes, you need I20040422 (or newer - I assume).
Yes.
bye
Stefan Matthias Aust // "Zweifel sind der Ansporn des Denkens..." -U
FUDForum. Page generated in 0.06600 seconds
