multiple data sources [message #146932] |
Wed, 22 March 2006 09:28 ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Originally posted by: mishra.vaibhav.gmail.com
Can I use use 2 different types of data sources in my report such that
data from 1st data source (which is JDBC data source) is used to fetch
some data from other data source (which is scripted data source)?
Example:
I am getting Employee Code (and some other columns) from 1st data source.
Now corresponding to this Employee Code, I want to show Employee Name in
the report which can be fetched using some Java API.
Vaibhav
Re: multiple data sources [message #147136 is a reply to message #146932] |
Wed, 22 March 2006 18:53 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) |
Originally posted by: David.Peterson.mtvnmix.com
Yes, on the table (or whatever) that you're displaying the inner data, right
click and select edit data binding. There are already 3-4 postings in the
forum discussing this topic, so if this isn't clear, just search and read
the others.
FUDForum. Page generated in 0.02165 seconds
