finding resource from GefEditPart [message #146646] |
Thu, 05 August 2004 15:18 ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Originally posted by: ra.classys.net
Hello everyone,
I am trying to identify the Workspace Project in which the resource i am
editing with a GEF Editor resides.
Can i dig my way from an subset of GefEditPart class?
If not at least from the GraphicalEditorWithPalette subset class ...
thank you,
Ra
Using Opera's revolutionary e-mail client: http://www.opera.com/m2/
Re: finding resource from GefEditPart [message #146652 is a reply to message #146646] |
Thu, 05 August 2004 15:37 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
One possible solution I work with:
Your Editor has an EditorInput which you can cast to an IFileEditorInput.
IFile file = ((IFileEditorInput)input).getFile();
The file instance has access to the workspace (getWorkspace()), it'
project and other Resources.
You can write a method in your Editor class for searching the required
resource.
Hope it helps,
Martin.
Re: finding resource from GefEditPart [message #146727 is a reply to message #146652] |
Fri, 06 August 2004 13:39 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) |
> resource.
> Hope it helps,
> Martin.
Yes, that was it. Thanks.
FUDForum. Page generated in 0.02976 seconds
