listening on 2 ports same time from SWT APP [message #146615] |
Thu, 09 June 2005 00:27 |
Originally posted by: sumit.panchasara.einfochips.com
I made one SWT app. using Eclipse. I am creating two buttons for server1,
server2 in a single application. When I press server1 it should start
listening on port 5555 and on pressing server2, should start listening on
6666.
Clients issues related commands and servers should accept both
connections(on related ports). e.g. client1 issues command for port 5555 and
client2 issues command for port 6666.
All clients are different machines.
Servers are on same machine. i.e. it is only one but listening on two
different ports.
Communication Protocol I have used is TCP/IP.
Now every thing is working fine. But for only one of these port. server
doesn't allow me to listen on second port. i.e. after pressing server1 I can
not able to press server2. Thus Client listening on port 6666 for example,
will not able to build connection with server.
What to do in this case?
Sumit.
FUDForum. Page generated in 0.03436 seconds
