Conflicting names [message #146434] |
Thu, 02 June 2005 09:01 ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Originally posted by: bluesboys.-remove-this-hotmail.com
Hi Group
I'm using namespaces in my project, and have the following two classes
namespace A
class foo //Interface
namespace A
namespace B
class foo //Implementation
The compilation runs without problems, but Eclipse shows an error under
problems, that I have conflicting names. Is there somewhere I can tell
Eclipse that it is ok, or shut down this check?
Best Regards
S
Re: Conflicting names [message #146521 is a reply to message #146434] |
Sun, 05 June 2005 05:15 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Originally posted by: emiliano.lesende.gmail.com
Hansen wrote:
> Hi Group
> namespace A
> namespace A
> namespace B
> Best Regards
> Søren Hansen
It might be a problem with the parser. If you can please post the source
code that causes the problem.
Emiliano
Re: Conflicting names [message #146534 is a reply to message #146521] |
Mon, 06 June 2005 06:24 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
"Emiliano Lesende" <emiliano.lesende@gmail.com> wrote in message
news:d7u1p9$6ar$2@news.eclipse.org...
> Hansen wrote:
>> Hi Group
>> namespace A
>> namespace A
>> namespace B
>> Best Regards
>> S
Re: Conflicting names [message #146541 is a reply to message #146534] |
Mon, 06 June 2005 16:11 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Originally posted by: simon.ou.edu
Hi Hansen...
> <<tramsportLayerInterface.hpp>>
> namespace communicationlayer
> class TransportLayer
> public:
> TransportLayer() {};
> ... (a number of virtual functions)
> <<transportLayer.hpp>>
> #include "TransportLayerInterface.hpp"
you are defining 'communicationlayer' namespace twice (above and below).
This is not allowed. Do you mean that you want to use the namespace
inside the new defined name space?
One possibility that you may want to consider the following... design
your classes with no name space. Just write normal code when defining
your classes and such. Now, when you implement them, then use namespaces.
namespace rs232
TransportLayer *tL = new TransportLayer();
main()
rs232::tL->init();
using namespace rs232
tL->yourCodeFunction();
and in this way you keep zero namespace corruption, which may be your
intended result after all.
Regards...
Miguel.
> namespace rs232
> class TransportLayer : public communicationlayer::TransportLayer
> public:
> TransportLayer(unsigned short comPort);
> ... (implementation of the virtual functions in transportLayerInterface.hpp)
> Best Regards
> Søren Hansen
Re: Conflicting names [message #146660 is a reply to message #146629] |
Thu, 09 June 2005 05:19 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Hi Andrew...
Yes, you are right. Splitting namespace definitions does compile/work
alright (any simple example can show this). Thank you for making this
point clear.
Regards...
Miguel
Andrew Niefer wrote:
> Assuming the missing closing braces in transportLayerInterface.hpp is just a
> typo, the idea is ok. Namespaces are allowed to be have their definitions
> split up like that and both communicationlayers are the same namespace.
> The problem marker is likely a bug with the parser. I don't know what
> version of CDT you are using, but in the latest from cvs (soon to be CDT
> 3.0M7) I don't get a problem marker with this pattern.
> -Andrew
Re: Conflicting names [message #146666 is a reply to message #146629] |
Thu, 09 June 2005 06:41 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
"Andrew Niefer" <aniefer@ca.ibm.com> wrote in message
news:d87fpv$rn3$1@news.eclipse.org...
> a
> definitions
I use the 3.1M6
-S
Re: Conflicting names [message #146978 is a reply to message #146666] |
Wed, 15 June 2005 17:54 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Originally posted by: devin_steffler.ca.ibm.com
3.1M6 must be the version of Eclipse that you are using. Do you know what
version of CDT you are using?
Devin
"Hansen" <bluesboys@-remove-this-hotmail.com> wrote in message
news:d88obd$2eb$1@news.eclipse.org...
just
> > a
> > definitions
> I use the 3.1M6
> -S
FUDForum. Page generated in 0.03781 seconds
