Re: Label offsets are ignored [message #146495 is a reply to message #146430] |
Tue, 14 August 2007 09:25 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) |
Originally posted by: 5d5.mail.ru
I'll check this but there should be no problems with negative values.
I've submitted #199841.
A.Schuster wrote:
> my purpose is to set 2 labels at the end of a connection. One above and
> one below the link. To achive this I set negative values for one of the
> labels. At the moment it seems that negative offsets are ignored.
> I've found some generated code with positive label offsets in a
> corresponding view factory. When I set negative values in the gmfgraph
> model there is no code generated for label offsets.
> Should negative label offsets normally work, or is there another way to
> set the label position?
> Cheers,
> Andreas
FUDForum. Page generated in 0.03685 seconds
