Home » Modeling » GMF (Graphical Modeling Framework) » GMF ecore editor and EMF validation framework
GMF ecore editor and EMF validation framework [message #1109] Mon, 31 July 2006 11:28 Go to next message
Validation framework overview article is really interresting. It proposes a
solution to validate EMF models even in cases EMFT based validation
solutions are not possible (eg : EMF "batch" use).
My concern is I dont have rose license and already did my design with GMF
ecore editor. So, I would like to find a way to design constraints in this
configuration.
OK, I know I am modeler addicted (and poor as well).
Is there a way to define constraints at design time with the GMF ecore
editor integration ?
I'm not sure this post is 100% GMF, I posted to EMF newsgroup just in case.
regards,
- Lucas
Re: GMF ecore editor and EMF validation framework [message #1162 is a reply to message #1109] Mon, 31 July 2006 12:30 Go to previous messageGo to next message
Hi Lucas,
Sure, you can use GMF ecore editor to design constraints for EMF generated
validators.
At the moment, only by plain creation of annotation elements the same way as
if edited in non-graphical ecore
editor.
There is no special constraint modeling support available now.
/Radek
"lucas bigeardel" <lucas.bigeardel@gmail.com> wrote in message
news:eal7j3$ihm$1@utils.eclipse.org...
> Hello,
> a
> configuration.
> case.
> regards,
> - Lucas
Re: GMF ecore editor and EMF validation framework [message #2191 is a reply to message #1162] Tue, 01 August 2006 09:09 Go to previous messageGo to next message
you're right I did it with simple annotations.
Did you managed to make it working with Annotations references.
In my case, reference values selected by ComboBox aren't "remembered".
I just created a EAnnotation, filling it according to EMFconstraints specs
and drag an drop it inside the EClass to be under validation.
The problem is that I'm not sure this is the best solution as I duplicate
EAnnotations.
Is there a way to define an EAnnotion and reusing it in several different
EClasses for EMF constraints validation code generation (eg: with Ecore
editor)?
regards,
- Lucas
"Radek Dvorak" <radek.dvorak@borland.com> wrote in message
news:ealb70$ibh$1@utils.eclipse.org...
> Hi Lucas,
> validators.
> as if edited in non-graphical ecore
> editor.
> /Radek
>> Hello,
>> a
>> this
>> configuration.
>> case.
>> regards,
>> - Lucas
Re: GMF ecore editor and EMF validation framework [message #2221 is a reply to message #2191] Tue, 01 August 2006 10:07 Go to previous messageGo to next message
If you look at the ecore metamodel, there is EModelElement class which can
contain EAnnotation elements via
'eAnnotations' reference and to my best knowledge of ecore, constraints are
extracted only from there.
So most probably, you can not reuse them due to the containment
relationship.
Anyway, you'd better check yourself ;-)
/Radek
news:eanjq9$n7u$1@utils.eclipse.org...
> EAnnotations.
> editor)?
> regards,
> - Lucas
>> Hi Lucas,
>> generated validators.
>> editor.
>> Regards,
>> /Radek
>>> Hello,
>>> proposes a
>>> GMF
>>> this
>>> configuration.
>>> case.
>>> regards,
>>> - Lucas
Re: GMF ecore editor and EMF validation framework [message #2559 is a reply to message #2221] Wed, 02 August 2006 10:03 Go to previous message
Hello Lucas,
Please ignore this if you have come across this kind of Ecore Editor
previously.
Check out the "Emphatic Editor" for creating Ecore files.
Madanagopal.
On Tue, 01 Aug 2006 16:07:31 +0200, Radek Dvorak
<radek.dvorak@borland.com> wrote:
> can
> are
> relationship.
> /Radek
>> specs
>> duplicate
>> EAnnotations.
>> different
>> editor)?
>> regards,
>> - Lucas
>>> Hi Lucas,
>>> way
>>> editor.
>>> Regards,
>>> /Radek
>>>> Hello,
>>>> proposes a
>>>> GMF
>>>> this
>>>> configuration.
>>>> case.
>>>> regards,
>>>> - Lucas
Previous Topic:Re: Opening an editor with focus on an element
Next Topic:Re: GMF errors
Current Time: Wed Nov 05 02:24:23 EST 2025
Powered by FUDForum. Page generated in 0.03827 seconds
