Home » Language IDEs » Java Development Tools (JDT) » Q: how to attach tomcat source while debugging..
Q: how to attach tomcat source while debugging.. [message #146365] Sun, 29 February 2004 16:11 Go to next message
Sundar Narasimhan is currently offline Sundar NarasimhanFriend
I'm trying to debug tomcat.. defining and using server configurations
work fine, and I can attach sources to all relevant component. But for
some reason even though I have unbundled and pointed it at the relevant
source folder WSAD gives me a blank screen when it steps into j2ee and
servlet code in tomcat. What gives? I can understand that I shouldn't
expect to be able to do this for WAS -- but tomcat should work, correct?
Thanks in advance.
Re: how to attach tomcat source while debugging.. [message #146517 is a reply to message #146365] Mon, 01 March 2004 14:23 Go to previous message
Darin Wright is currently offline Darin WrightFriend
Should work. If you're using a Java Application launch configuration, you
can modify the source lookup path on the "Source" tab.
Darin
"Sundar Narasimhan" <sundar@ascent.com> wrote in message
news:c1t2s4$sc4$1@eclipse.org...
> Thanks in advance.
Previous Topic:Add JavaDoc for whole file
Next Topic:serialVersionUID not compatible
Current Time: Mon Dec 30 16:36:17 GMT 2024
Powered by FUDForum. Page generated in 0.02931 seconds
