Activating Undo, Redo & Delete in MenuBar? [message #146292] |
Tue, 03 August 2004 11:54  |
Originally posted by: mastr.arcor.de
Hey @ll!
How can I activate the menuitems "Undo", "Redo", "Delete" for Menu "Edit"?
I have an ActionRegistry, Actions added to it, a CommandStack and a
CommandStackListener. (I don't have sth. like an UpdateAction)
Do I need a gef.ActionBarContributor for that?
...If yes, how do I implement it for GEF 2.0.3 (com.ibm.etools).
Or does it work with only implementing ui.part.EditorActionBarContributor?
Else what is missing?
Thanks in advance.
Martin
Re: Activating Undo, Redo & Delete in MenuBar? [message #146479 is a reply to message #146292] |
Wed, 04 August 2004 11:29   |
Originally posted by: rlemaigr.ulb.ac.be
> How can I activate the menuitems "Undo", "Redo", "Delete" for Menu =
> "Edit"?
> Or does it work with only implementing =
> Thanks in advance.
> Martin
You have to tell to Eclipse what it has to do when you editor is active =
and when the
user selects the undo, redo, delete...menu items. This is implemented by=
"retargetable actions"
("global actions"). I don't remember the code to contribute to them, but=
I =
remember
it is very well explained in the Eclipse doc. There are just some lines =
of =
code to add
in your EditorPart class.
I hope this will help,
r=E9gis
Re: Activating Undo, Redo & Delete in MenuBar? [message #146562 is a reply to message #146292] |
Wed, 04 August 2004 17:55  |
These actions are probably working with the logic example for that release.
That would be the best source for answers. It is probably the same as now,
you must register a global action handler.
"mastr" <mastr@arcor.de> wrote in message news:ceocft$3av$1@eclipse.org...
> Hey @ll!
> Thanks in advance.
> Martin
FUDForum. Page generated in 0.28608 seconds
