Home » Eclipse Projects » Commercial » Integration of BIRT + Web application
Integration of BIRT + Web application [message #13586] Mon, 16 July 2007 08:16 Go to next message
Originally posted by: bprashant_b.yahoo.co.in
How i can integrate report generated by BIRT in my Web application?
Please suggest me what are the changes required to do in web.xml of my
application , what are different types of lib. files required to be added?
Re: Integration of BIRT + Web application [message #13671 is a reply to message #13586] Fri, 20 July 2007 06:37 Go to previous message
Originally posted by: naresh.t.servion.com
While You Integrating the rpt design in the webApplication you create
the application as the webproject and it will create thefolder
structure
in that you just create the java code to interact with the .rptdesign.
The API for DesignEngine as well as ReportEngine will provide by Eclipse.
Thanks & regards
Naresh.T
Re: Integration of BIRT + Web application [message #564220 is a reply to message #13586] Fri, 20 July 2007 06:37 Go to previous message
structure
Thanks & regards
Naresh.T
Previous Topic:BIRT Error
Next Topic:JointLogic Web Designer 1.4.0 released
Current Time: Wed Apr 16 00:27:46 EDT 2025
Powered by FUDForum. Page generated in 0.03246 seconds
