Home » Eclipse Projects » OSEE » Data dictionary
Data dictionary [message #13578] Thu, 23 April 2009 05:16 Go to next message
This may be a dumb question, in which case I apologise!
What is the intended method of creating a data dictionary in OSEE?
I ask because tools in the past have had either a single "file" or the
interfaces have been defined for each subsystem and the DD generated by
scripting from the database. I haven't seen anything obvious for either in
OSEE at the moment - I appreciate that it may be expected to be done by
customisation but don't want to reinvent the wheel!
Re: Data dictionary [message #13667 is a reply to message #13578] Fri, 24 April 2009 20:17 Go to previous messageGo to next message
Mark,
Please see http://wiki.eclipse.org/OSEE/Developers_Guide#Custom_Data_Mo del
for documentation on how to define a custom data model and a link to an
example. We are also putting together a comprehensive systems engineering
data model that people can use as a starting point, but that is not ready
yet. I will post to the newsgroup when it is ready.
Ryan
Re: Data dictionary [message #13709 is a reply to message #13667] Tue, 28 April 2009 10:06 Go to previous messageGo to next message
Thanks Ryan.
By the way, the link to
https://dev.eclipse.org/svnroot/technology/org.eclipse.osee/ trunk/org.eclipse.osee.framework.skynet.core/support/Program AndCommon.xml
yields a 404 not found.
Re: Data dictionary [message #13730 is a reply to message #13709] Tue, 28 April 2009 14:20 Go to previous messageGo to next message
Mark D-B wrote:
> Thanks Ryan.
I had the same problem before, i have backtracked to the right xml file,
the link was renamed i guess, anyways the link is
https://dev.eclipse.org/svnroot/technology/org.eclipse.osee/ trunk/org.eclipse.osee.framework.skynet.core/support/OseeTyp es_ProgramAndCommon.xml
Re: Data dictionary [message #14476 is a reply to message #13730] Fri, 01 May 2009 08:12 Go to previous message
Thank you for that - there's a subtle difference between that one and the
one I found in the SVN archive.
Re: Data dictionary [message #573098 is a reply to message #13578] Fri, 24 April 2009 20:17 Go to previous message
Mark,
Ryan
Re: Data dictionary [message #573137 is a reply to message #13667] Tue, 28 April 2009 10:06 Go to previous message
Thanks Ryan.
Re: Data dictionary [message #573163 is a reply to message #13709] Tue, 28 April 2009 14:20 Go to previous message
Mark D-B wrote:
> Thanks Ryan.
Re: Data dictionary [message #573388 is a reply to message #13730] Fri, 01 May 2009 08:12 Go to previous message
Previous Topic:osee exe files
Next Topic:Custom data model - how to specify type inheritance
Current Time: Wed Apr 16 00:30:01 EDT 2025
Powered by FUDForum. Page generated in 0.03075 seconds
