Home » Modeling » GMF (Graphical Modeling Framework) » Fixed element size from the beginning
Fixed element size from the beginning [message #145980] Thu, 09 August 2007 09:26 Go to next message
does anyone know, how I can make sure that an item will always have a
fixed size? I set the non-resize constraints, and it works, but if I make
a new element I can still give any size the element. I think there was a
post about this, but I cannot find it. So I would like to make sure, that
an object like a rectangle will always have the shape of a square.
Thank you for your interest.
Re: Fixed element size from the beginning [message #146009 is a reply to message #145980] Thu, 09 August 2007 11:14 Go to previous messageGo to next message
did you already try to set minimum size, max. size and preferred size?
-stefan
Malte schrieb:
> Hello,
> make a new element I can still give any size the element. I think there
> was a post about this, but I cannot find it. So I would like to make
> sure, that an object like a rectangle will always have the shape of a
> square.
Re: Fixed element size from the beginning [message #146053 is a reply to message #146009] Fri, 10 August 2007 04:29 Go to previous messageGo to next message
Oh yes of course, but this seems to be only recommendations. The min-size
for example is overwritten if the labels need more place. If somebody
could give some links to other posts, I can try to solve my problem by
myself.
Thank you for your answer.
> -stefan
> Malte schrieb:
>> Hello,
>> square.
Re: Fixed element size from the beginning [message #146116 is a reply to message #146053] Fri, 10 August 2007 05:40 Go to previous message
personally I haven't experienced that min-size is overritten. But if you
say so you could still force it if you extend the figure-type of your
base figure, change your base figure to a custom figure (in gmfGraph)
and override min,pref and maxsize in your extending figure to the
desired value. Already tried this?
-stefan
> min-size for example is overwritten if the labels need more place. If
> somebody could give some links to other posts, I can try to solve my
> problem by myself.
>> -stefan
>> Malte schrieb:
>>> Hello,
>>> there was a post about this, but I cannot find it. So I would like to
>>> make sure, that an object like a rectangle will always have the shape
>>> of a square.
Previous Topic:Editor still "dirty" after a full undo
Next Topic:GMF2.0 disappeared visual elements.
Current Time: Sat Nov 08 12:25:08 EST 2025
Powered by FUDForum. Page generated in 0.04470 seconds
