How to integrate validation framework with GMF? [message #145475] |
Mon, 06 August 2007 18:55 |
John Smith Messages: 137 Registered: July 2009 |
I did a ObjectContribution to EditPart, with an action, and when my
action is run, I extract my EObjects from the selected EditParts and
trigger the installed validation constraints, like it is done in the
validation example for the library metamodel. However I now have the
"model" eobjects (since the containts need them as "self" objects) and
the created IStatus objects refer to them, but not to the EditParts.
Thus, when a marker is navigated, an editor for the model is searched to
open the model element, but not my (already opened) GMF editor. Infact,
the GMF editor has a diagram model. So how do I achieve to open the
diagram model element related to my real model element?
Thanks in advance
Re: How to integrate validation framework with GMF? [message #145567 is a reply to message #145475] |
Tue, 07 August 2007 13:14 |
Boris Blajer Messages: 217 Registered: July 2009 |
Hi exquisitus,
You need to re-associate underlying model objects with notational
objects that wrap those objects on your diagram. If I'm not mistaken,
this is already performed by the generated validation mechanism.
Boris
exquisitus wrote:
> Thanks in advance
FUDForum. Page generated in 0.03183 seconds
