BPMN Tutorial - Code Generation and Testing (bpmn.edit missing) [message #145367] |
Sun, 05 August 2007 22:40 ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Originally posted by: wulf.franke.gmail.com
http://wiki.eclipse.org/index.php/GMF_Tutorial_BPMN
I was following the tutorial and so far everything was working out for me.
"- In the Run > Run… dialog, create a new Eclipse Application
configuration named ‘bpmn’ (adjust runtime workspace directory if desired)"
"- Run the workspace, create a new basic project and new ‘Bpmn Diagram’
(under Examples in New dialog)"
I believe the reason is the missing bpmn.edit in my workspace but the
tutorial does not say anything about its creating.
Eclipse Errors:
Severity and Description Path Resource Location Creation Time Id
BpmnItemProviderAdapterFactory cannot be resolved to a type
bpmn.diagram/src/bpmn/diagram/part BpmnDiagramEditorPlugin.java line
97 1186319321234 993
Bundle 'bpmn.edit' cannot be resolved bpmn.diagram/META-INF MANIFEST.MF
line 35 1186319321671 994
The import bpmn.provider cannot be resolved
22 1186319321234 992
+ several warnings about "Type safety"
Eclipse 3.2.1 and GMF 1.0.1 (org.eclipse.gmf.sdk (1.0.0.v20060713-1700))
In the end Bpmn Diagram does not show up under Examples in New Dialog.
Did i miss something?
Wulf
FUDForum. Page generated in 0.03504 seconds
