Home » Archived » Test and Performance Tools Platform (TPTP) » Cant see (Run > Run As > Run-time Workbench)
Cant see (Run > Run As > Run-time Workbench) [message #13514] Tue, 05 April 2005 02:05 Go to next message
Originally posted by: prasen.bea.com
Trying to Run "Log Parser Sample". I followed the readme.html till I
get to the stage where it asks me to create a run-time instance of the
Workbench (Run > Run As > Run-time Workbench).
I cant see any "Run-time Workbench" under Run-> Run As.
What am I doing wrong here ?
thanks,
prasen
Re: Cant see (Run > Run As > Run-time Workbench) [message #13566 is a reply to message #13514] Tue, 05 April 2005 09:01 Go to previous messageGo to next message
Hi Prasen,
In Eclipse v3.1 (Eclipse base for TPTP v4.0), "Run-time Workbench" has
been changed to "Eclipse Application". As such:
Run > Run As > Eclipse Application
I will open a defect to have this changed in all of the TPTP v4.0
samples.
Paul
<prasen@bea.com> wrote in message news:d2ta0j$qit$1@news.eclipse.org...
> thanks,
> prasen
Re: Cant see (Run > Run As > Run-time Workbench) [message #13587 is a reply to message #13566] Tue, 05 April 2005 10:14 Go to previous messageGo to next message
I realized that later. But I dont get to see "Eclipse Application"
either for LogParserProject in 3.1. Although if I use 3.0.0 then I can
see Run As > Run-time Workbench. But if I use 3.0.0 I dont get to see
"Simple Parser V1.0" in AddLogFile wizard.
And LogParserproject doesnt seem to work with 3.1 out-of-the-box. What
do I need to do to make it work in 3.1 ?
Any other combination of eclipse/haydes-tool will work oob ?
thanks,
prasen
Paul Slauenwhite wrote:
> Hi Prasen,
> samples.
> Paul
>>thanks,
>>prasen
Re: Cant see (Run > Run As > Run-time Workbench) [message #13608 is a reply to message #13587] Tue, 05 April 2005 10:29 Go to previous messageGo to next message
OK. I deleted one of the plugin-import and it seem to worked
<requires>
<!-- <import
plugin="org.eclipse.hyades.logging.adapter.config"/> -->
<import plugin="org.eclipse.hyades.logging.parsers"/>
</requires>
thanks,
prasen
> thanks,
> prasen
>> Hi Prasen,
>> has
>> samples.
>> Paul
>>> thanks,
>>> prasen
Re: Cant see (Run > Run As > Run-time Workbench) [message #13814 is a reply to message #13608] Wed, 06 April 2005 11:17 Go to previous message
Hi Prasen,
This dependency problem has been fixed in the latest TPTP v4.0. This
example is also fully functional in the latest Hyades v3.3 driver.
Paul
<prasen@bea.com> wrote in message news:d2u7j4$6s5$1@news.eclipse.org...
> <requires>
> <!-- <import
> </requires>
> thanks,
> prasen
> > thanks,
> > prasen
> >> Hi Prasen,
> >> has
> >> samples.
> >> Paul
> >>> thanks,
> >>> prasen
Previous Topic:Release 4i2 ?
Next Topic:Howto activate profiling during test execution
Current Time: Thu Apr 24 00:09:06 EDT 2025
Powered by FUDForum. Page generated in 0.04094 seconds
