Re: Eclipse 3.4 Ganymede (J2EE) + non official VE = can't use visual plugin for [message #145377 is a reply to message #145323] |
Tue, 14 October 2008 04:22 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Jason Kolter![Friend of Eclipse Friend](/donate/web-api/friends_decorator.php?email=jkolter%40gmail.com) Messages: 15 Registered: July 2009 |
Junior Member |
I'm having the same problem as described below. I can view and edit Swing
and SWT classes, but when I try to edit or create an RCP view/editor I get
an error popup that says:
Error trying to set new file into editor.
Reason: java.lang.NullPointerException
I am using Eclipse 3.4, and I've tried to install using the "non-official"
update site, the "www.ehecht.com" method, as well as the old "Visual
Editor patched as in bug 202562" method, and the error seems to occur in
all cases.
Is anyone else having this trouble and/or aware of it?
Jachym wrote:
> Hi, i try Eclipse 3.4 Ganymede (J2EE) + VE (non official
> http://wiki.eclipse.org/VE/Update )
> But it work only half,
> -> new Visual Class
> --> RCP : not work
> --> SWT : work
> With RCP i have the same result, Eclipse
> 1/ Create new File
> 2/ Split the screen for code and preview
> 3/ The rendering fail, with a java.lang.NullPointerException
> Finaly, i did not use the graphical option of this (great and old) plugin.
> I also try this zip : http://www.ehecht.com/eclipse_ve/ve.html
> (ve_eclipse_34_200807092330_win.zip) for the same result.
> Other person are in the same case?
Re: Eclipse 3.4 Ganymede (J2EE) + non official VE = can't use visual plugin for [message #145385 is a reply to message #145377] |
Tue, 14 October 2008 06:35 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Originally posted by: gemaspecial.yahoo.com.hk
Me 2. Same error.
org.eclipse.ve.internal.swt.ControlManager.refreshImage(Cont rolManager.java:934)
org.eclipse.ve.internal.rcp.WorkbenchPartProxyAdapter.refres hImage(WorkbenchPartProxyAdapter.java:493)
org.eclipse.ve.internal.cde.core.ImageFigureController.setIm ageNotifier(ImageFigureController.java:174)
org.eclipse.ve.internal.rcp.WorkbenchPartGraphicalEditPart.a ctivate(WorkbenchPartGraphicalEditPart.java:170)
org.eclipse.gef.editparts.AbstractEditPart.activate(Abstract EditPart.java:152)
org.eclipse.gef.editparts.AbstractGraphicalEditPart.activate (AbstractGraphicalEditPart.java:193)
org.eclipse.ve.internal.java.core.CompositionComponentsGraph icalEditPart.activate(CompositionComponentsGraphicalEditPart .java:88)
org.eclipse.ve.internal.java.vce.SubclassCompositionComponen tsGraphicalEditPart.activate(SubclassCompositionComponentsGr aphicalEditPart.java:70)
org.eclipse.ve.internal.java.codegen.editorpart.JavaVisualEd itorPart.setRootModel(JavaVisualEditorPart.java:505)
org.eclipse.ve.internal.java.codegen.editorpart.JavaVisualEd itorPart.initializeViewers(JavaVisualEditorPart.java:1121)
org.eclipse.ve.internal.java.codegen.editorpart.JavaVisualEd itorPart$Setup$2.run(JavaVisualEditorPart.java:2098)
at org.eclipse.swt.widgets.RunnableLock.run(RunnableLock.java:3 5)
org.eclipse.swt.widgets.Synchronizer.runAsyncMessages(Synchr onizer.java:133)
at org.eclipse.swt.widgets.Display.runAsyncMessages(Display.jav a:3800)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :3425)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.jav a:2382)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2346)
at org.eclipse.ui.internal.Workbench.access$4(Workbench.java:21 98)
at org.eclipse.ui.internal.Workbench$5.run(Workbench.java:493)
org.eclipse.core.databinding.observable.Realm.runWithDefault (Realm.java:288)
org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Work bench.java:488)
org.eclipse.ui.internal.ide.application.IDEApplication.start (IDEApplication.java:113)
org.eclipse.equinox.internal.app.EclipseAppHandle.run(Eclips eAppHandle.java:193)
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .runApplication(EclipseAppLauncher.java:110)
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .start(EclipseAppLauncher.java:79)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:382)
at org.eclipse.equinox.launcher.Main.main(Main.java:1212)
> Swing and SWT classes, but when I try to edit or create an RCP
> view/editor I get an error popup that says:
> "non-official" update site, the "www.ehecht.com" method, as well as the
> old "Visual Editor patched as in bug 202562" method, and the error seems
> to occur in all cases.
>> -> new Visual Class
>> --> RCP : not work
>> --> SWT : work
>> 1/ Create new File
>> plugin.
Re: Eclipse 3.4 Ganymede (J2EE) + non official VE = can't use visual plugin for [message #617292 is a reply to message #145323] |
Tue, 14 October 2008 04:22 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) |
Junior Member |
all cases.
> -> new Visual Class
> --> RCP : not work
> --> SWT : work
> 1/ Create new File
Re: Eclipse 3.4 Ganymede (J2EE) + non official VE = can't use visual plugin for [message #617293 is a reply to message #145377] |
Tue, 14 October 2008 06:35 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) |
Leung Wang Hei![Friend of Eclipse Friend](/donate/web-api/friends_decorator.php?email=gemaspecial%40yahoo.com.hk) Messages: 64 Registered: July 2010 |
Member |
Me 2. Same error.
>> -> new Visual Class
>> --> RCP : not work
>> --> SWT : work
>> 1/ Create new File
>> plugin.
FUDForum. Page generated in 0.04467 seconds
