Home » Language IDEs » C / C++ IDE (CDT) » Managing projects
Managing projects [message #145074] Thu, 12 May 2005 02:52 Go to next message
Originally posted by: bluesboys.-remove-this-hotmail.com
Hi all
Is it possible in CDT to include a directory to a project, without CDT
actually copying the files to the project library? I'm making a protocol
which is to be build for to different platforms, and much of the stuff are
the same except the HW-layer.
Therefore I would like to have 2 project which contains the same
directories, except for the Hw-wrapper. So if I change in a shared file in
on project, the change is also applied in the other project, because it's
the same file.
Best Regards
S
Re: Managing projects [message #145082 is a reply to message #145074] Thu, 12 May 2005 15:08 Go to previous messageGo to next message
Originally posted by: eclipse.rocketcomp.com.au
I use the same folders for VS and eclipse, but I've found that to import an
existing file into eclipse, I have to cut it out of the directory, paste it
somewhere else and then import it back into the folder. eclipse seems to
actually want the file in the folder rather tan just storing a link to it.
Hansen wrote:
> Hi all
> the same file.
> Best Regards
> Søren Hansen
Re: Managing projects [message #145088 is a reply to message #145082] Fri, 13 May 2005 01:47 Go to previous messageGo to next message
> Hansen wrote:
>> Hi all
>> are the same except the HW-layer.
>> in on project, the change is also applied in the other project, because
>> it's the same file.
>> Best Regards
>> S
Re: Managing projects [message #145416 is a reply to message #145088] Fri, 13 May 2005 11:38 Go to previous messageGo to next message
You could create a seperate project with that common code by specifying the
contents directory in the new project wizard (instead of using the default
directory and then importing the code to there). Then import that project
into the same workspace as your working project and set your working project
to reference it (project properties->Project References)
-Andrew
"Hansen" <bluesboys@-remove-this-hotmail.com> wrote in message
news:d61fij$46l$1@news.eclipse.org...
> > Hansen wrote:
> >> Hi all
protocol
> >> it's the same file.
> >> Best Regards
> >> S
Re: Managing projects [message #145624 is a reply to message #145074] Wed, 18 May 2005 08:15 Go to previous message
Originally posted by: jonas.nightnmode.org
The problem (as I see it) is that your workbench would then contain two
views of the same file which may not be too nice. In your case you should
probably compile the hw-layer in a separate library project, and link with
that library from your main project. Then you make a different
configuration for each hardware (requires you to use Managed projects).
Hansen wrote:
> Hi all
> the same file.
> Best Regards
> Søren Hansen
Previous Topic:What's needed for multi platform/configuration
Next Topic:target file lock up
Current Time: Wed Oct 29 05:17:40 EDT 2025
Powered by FUDForum. Page generated in 0.04846 seconds
