Failure to Invoke Editor [message #144858] |
Fri, 16 May 2008 17:12 |
Originally posted by: remande.alum.wpi.edu
I've installed Eclipse 3.2.2, GEF 3.2.0, and Visual Editor 1.2.1.
However, I can't seem to reach the visual editor. When I "Edit with..." a
file, I don't get a Visual Editor option. When I use the "new Java class"
button on the toolbar, my options are "JUnit test case", "class",
"interface", "enum", and "annotation". But when I go to Help->Software
Updates->Manage Configuration, my Visual Editor package is installed and
enabled, with a sub-package of Java EMF model 1.2.3.
So Eclipse says it's all installed...I just don't get the features.
I'm running on XP Pro over x86. Eclipse is configured to use Java 5.0
compliance.
Any ideas?
Thanks in advance,
--Rob Mandeville
Re: Failure to Invoke Editor [message #144867 is a reply to message #144858] |
Fri, 16 May 2008 21:11 |
Rob,
Are you sure you're using a 5.0 JVM? Trying running with -clean -debug
and look at the Error log view (<workspace>/.metadata/.log) for clues
why the features might be disabled.
> with..." a file, I don't get a Visual Editor option. When I use the
> "new Java class" button on the toolbar, my options are "JUnit test
> case", "class", "interface", "enum", and "annotation". But when I go
> to Help->Software Updates->Manage Configuration, my Visual Editor
> package is installed and enabled, with a sub-package of Java EMF model
> 1.2.3.
> compliance.
> Any ideas?
> Thanks in advance,
> --Rob Mandeville
Re: Failure to Invoke Editor [message #617203 is a reply to message #144858] |
Ed Merks Messages: 33214 Registered: July 2009 |
Rob,
> 1.2.3.
> compliance.
> Any ideas?
> Thanks in advance,
> --Rob Mandeville
Ed Merks
FUDForum. Page generated in 0.03213 seconds
