Home » Eclipse Projects » Buckminster dev » [buckminster-dev] RE: buckminster-dev Digest, Vol 32, Issue 18
[buckminster-dev] RE: buckminster-dev Digest, Vol 32, Issue 18 [message #13455] Thu, 27 March 2008 12:47
Originally posted by: ikalboussi.ilog.fr
Hi Stefan
Thanks for answering me so fast, as I'm a beginner at Buckminster ( I
have read all the documentation in: http://www.eclipse.org/buckminster
I've faced many problems :)
1) When I try to execute the hello world of Buckminster
( http://wiki.eclipse.org/Hello_XML_World_Example_%28Buckminst er%29)
The following message is displayed:
java.lang.StackOverflowError
2) In my Rmap ,I need to point only maven repositories ,the problem is
that when I specify a component type (maven) I don't know really the
syntax to follow (should I specify a path to my pom.xml or what?)
i need an exemple to clarify this.
-----Original Message-----
[mailto:buckminster-dev-bounces@eclipse.org] On Behalf Of
buckminster-dev-request@eclipse.org
Sent: jeudi 27 mars 2008 17:00
To: buckminster-dev@eclipse.org
Subject: buckminster-dev Digest, Vol 32, Issue 18
Send buckminster-dev mailing list submissions to
To subscribe or unsubscribe via the World Wide Web, visit
https://dev.eclipse.org/mailman/listinfo/buckminster-dev
or, via email, send a message with subject or body 'help' to
You can reach the person managing the list at
buckminster-dev-owner@eclipse.org
When replying, please edit your Subject line so it is more specific
than "Re: Contents of buckminster-dev digest..."
Today's Topics:
1. how can I build my eclipse plugin? (Imen Kalboussi)
2. Maven and rmap (Imen Kalboussi)
3. Re: Maven and rmap (Stefan Daume)
Message: 1
Date: Thu, 27 Mar 2008 09:20:24 +0100
Subject: [buckminster-dev] how can I build my eclipse plugin?
To: <buckminster-dev@eclipse.org>
Message-ID: <3E5E1A634BBD5C4A94C4D4A6DE0852E7DF3B3D@parmbx02.ilog.biz>
Content-Type: text/plain; charset="us-ascii"
Actually I have to build eclipse plugins in order to get at the end an
artifact (a jar) that contains a plugin and all the plugins that
depends on him.
So after writing a CQUERY and RMAP I don't know how to get the final
artifact with Buckminster.
I would be grateful if someone will try to help me .
-------------- next part --------------
An HTML attachment was scrubbed...
URL:
https://dev.eclipse.org/mailman/private/buckminster-dev/atta chments/2008
0327/5b98f9ba/attachment.html
Message: 2
Date: Thu, 27 Mar 2008 14:27:31 +0100
Subject: [buckminster-dev] Maven and rmap
Message-ID: <3E5E1A634BBD5C4A94C4D4A6DE0852E7DF3C01@parmbx02.ilog.biz>
I think I have solve my problem it was very simple but now I have to
solve the dependencies between plugins, so if a plugin
A need a plugin B ; I must mention this kind of dependency on the RMAP
the problem is that Ilike this plugins would be bring from a maven
repository
The only thing that I know is that the pom.xml must be mention but the
syntax that I wrote is always wrong :-(
So is there any one who can give he right syntax when I'm looking
basically for an extended jar type but assuming Maven repository
dependency information contained in a Pom.
Thanks.
________________________________
Sent: jeudi 27 mars 2008 09:20
To: 'buckminster-dev@eclipse.org'
Subject: how can I build my eclipse plugin?
depends on him.
URL:
0327/bd4f07e1/attachment.html
Message: 3
Date: Thu, 27 Mar 2008 15:05:06 +0100
Subject: Re: [buckminster-dev] Maven and rmap
To: Buckminster developer discussions <buckminster-dev@eclipse.org>
Message-ID: <47EBA992.9090109@cloudsmith.com>
Content-Type: text/plain; charset=windows-1252; format=flowed
Hi Imen,
I am not sure I have understood what you mean when you say that "you
must mention the dependency in the RMAP". The RMAP is just a pointer to
the repositories that will or may contain the components you require. A
dependency will be captured by the plugin information where it would be
discovered automatically or it could be expressed explicitly in a
buckminster.cspec that you created. But in a basic plugin development
usecase you would not have to do that.
Could you post the RMAP that you have prepared to this list, so we can
have a look at what you have done so far ? And/or provide as much
additonal context as possible.
Stefan
Imen Kalboussi wrote:
> repository
> syntax that I wrote is always wrong L
> Thanks.
> *From:* Imen Kalboussi
> *Sent:* jeudi 27 mars 2008 09:20
> *To:* 'buckminster-dev@eclipse.org'
> *Subject:* how can I build my eclipse plugin?
> depends on him.
> Thanks
> _______________________________________________
End of buckminster-dev Digest, Vol 32, Issue 18
Previous Topic:Re: [buckminster-dev] Maven and rmap
Next Topic:RE:[buckminster-dev] Maven and rmap (and possible resolution for StackOverflowError)
Current Time: Wed Apr 16 00:27:55 EDT 2025
Powered by FUDForum. Page generated in 0.24356 seconds
