Changing IDE background colour under Motif [message #144836] |
Thu, 16 October 2003 10:45 |
Originally posted by: glenn.ebi.ac.uk
[originally posted to eclipse.tools.jdt, but I think this group is more appropriate]
I'm a relative newcomer to Eclipse, having used various other IDEs in the past.
I'm using the Eclipse Platform v 3.0.0 under Linux. I don't have GTK2 installed
so I'm using the Motif version.
However the IDE has a grey background for everything, and I can't find a way to
change it. Can this be done within the IDE or does it require some sort of
X11/Motif flag at startup?
TIA
Glenn.
Re: Changing IDE background colour under Motif [message #145587 is a reply to message #144836] |
Fri, 17 October 2003 10:51 |
Originally posted by: use.reply.to.invalid
> way to
The SWT FAQ has an entry about changing stuff in Motif. You should set
this via an X resource before starting eclipse. Search for xrdb.
Thorbjoern Ravn Andersen "...plus...Tubular Bells!"
FUDForum. Page generated in 0.03831 seconds
