C++ refactoring [message #144675] |
Thu, 05 May 2005 18:05 |
Originally posted by: gshiman.commvault.com
I installed CDT plugin hoping to use in C++ the rich refactiring support
available to Java developers. But currently refactoring support is limited
to rename refactoring. Does anyone work to add more?
- George
Re: C++ refactoring [message #144733 is a reply to message #144675] |
Thu, 05 May 2005 20:33 |
> limited to rename refactoring. Does anyone work to add more?
I believe they have people working on it, but refactoring C++ is
significantly more difficult than refactoring Java. (One of my
colleagues is doing her PhD thesis entirely on the complications
introduced by the preprocessor.) So, yes, I believe it's in the works,
but I think a totally robust, comprehensive C++ refactoring tool is
still a ways off...
Jeff Overbey
University of Illinois at Urbana-Champaign
Photran Team - http://www.photran.org/
Re: C++ refactoring [message #144751 is a reply to message #144733] |
Thu, 05 May 2005 23:16 |
Originally posted by: btabenkin.verizon.net
Is it possible to do ctrl-click naviagation like you can do in Java? It
seems to find the variable declaration, but not class to class. Also,
code generation (create a new class, and ctrl-1 to create it)
>> support available to Java developers. But currently refactoring
>> support is limited to rename refactoring. Does anyone work to add more?
> still a ways off...
> Jeff Overbey
Re: C++ refactoring [message #144769 is a reply to message #144733] |
Fri, 06 May 2005 14:26 |
Originally posted by: dschaefe.ca.ibm.com
"Jeff Overbey" <overbey2@uiuc.edu> wrote in message
news:d5e09o$2cs$1@news.eclipse.org...
> significantly more difficult than refactoring Java. (One of my colleagues
> is doing her PhD thesis entirely on the complications introduced by the
> preprocessor.) So, yes, I believe it's in the works, but I think a
> totally robust, comprehensive C++ refactoring tool is still a ways off...
It comes and goes. The rename refactoring we currently have is pretty weak.
We have some better rename refactoring in the pipe that uses the platform
LTK. I don't think that's going to make it for 3.0, though.
As Jeff mentioned, this stuff is pretty hard and will take a lot of research
effort to get it right, although I am encouraged with the work being done at
UIUC. We're going to need more volunteers, though, to get this into the CDT
with good quality and scalability.
Doug.
FUDForum. Page generated in 0.04433 seconds
