| Problems with generating diagram code with GMF 2.0 [message #144626] |
Sat, 28 July 2007 20:28  |
I used Eclipse 3.2.2, EMF 2.2, and GMF 1.0.3 to create EMF/GMF Editors.
The Editors are working fine.
however, I want to use the latest JET2 build, which requires Eclipse 3.3
and EMF 2.3, to generate Java code from the file produced by the editors.
so, I have to use Eclipse 3.3 to be able to use the latest JET2 with the
fixed bugs.this means, I have to use GMF 2.0 too.
I dowanloaded the latest version of Eclipse 3.3, GMF 2.0 and all its
requirements listed in its webpage.
The problem is:
when I wanted to generate Diagrame code from my *.gmfgen I got the
following error message:
Problems while generating code
Exception (Couldn't find operation 'isSuperTypeOf(EClass)' for EEnum.:in
xpt::editor::GenDiagram on line 35
'(EClass)gf.ecoreFeature.eType.isSuperTypeOf(eType)') while generating code
where the line 35 is:
<elementType
line 35 xsi:type="gmfgen:MetamodelType"
editHelperClassName="StateEditHelper"/>
I also tried to use my models created using Eclipse 3.2.2 and GMF 1.0.3 by
importing the models in Eclipse 3.3 and use "Migrate to GMF 2.0" for
gmfgraph, .gmfmap and .gmfgen but I got the same error message.
BTW: I used XML schema to produce my EMF model. also here is my *.ecore
model to give you an idea about my model:
<ecore:EPackage xmi:version="2.0"
xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"
xmlns:ecore="http://www.eclipse.org/emf/2002/Ecore" name="xmachine"
nsURI="http://www.eclipse.org/xmachine" nsPrefix="xmachine">
<eClassifiers xsi:type="ecore:EDataType" name="AllowedChar"
instanceClassName="java.lang.String">
<eAnnotations
source="http:///org/eclipse/emf/ecore/util/ExtendedMetaData">
<details key="name" value="allowed-char"/>
<details key="baseType"
value="http://www.eclipse.org/emf/2003/XMLType#string"/>
<details key="pattern" value="([a-zA-Z0-9_])"/>
</eAnnotations>
</eClassifiers>
<eClassifiers xsi:type="ecore:EDataType" name="AllowedString"
<eAnnotations
<details key="name" value="allowed-string"/>
<details key="pattern" value="([a-zA-Z0-9_])*"/>
</eAnnotations>
</eClassifiers>
<eClassifiers xsi:type="ecore:EClass" name="ArithmeticBinaryType">
<eAnnotations
<details key="name" value="arithmetic-binary_._type"/>
<details key="kind" value="elementOnly"/>
</eAnnotations>
<eStructuralFeatures xsi:type="ecore:EReference" name="arg"
lowerBound="1" eType="#//ListElement"
containment="true" resolveProxies="false">
<eAnnotations
<details key="kind" value="element"/>
<details key="name" value="arg"/>
<details key="namespace" value="##targetNamespace"/>
</eAnnotations>
</eStructuralFeatures>
<eStructuralFeatures xsi:type="ecore:EAttribute"
name="arithmeticOperator" lowerBound="1"
eType="#//ArithmeticOperator" defaultValueLiteral="plus"
unsettable="true">
<eAnnotations
<details key="name" value="arithmetic-operator"/>
</eAnnotations>
name="arithmeticExpression" lowerBound="1"
eType="#//ArithmeticExpressionType" containment="true"
<eAnnotations
<details key="name" value="arithmetic-expression"/>
</eAnnotations>
</eClassifiers>
<eClassifiers xsi:type="ecore:EClass" name="ArithmeticExpressionType">
<eAnnotations
<details key="name" value="arithmetic-expression_._type"/>
</eAnnotations>
<eAnnotations
</eAnnotations>
name="arithmeticBinary" eType="#//ArithmeticBinaryType"
<eAnnotations
<details key="name" value="arithmetic-binary"/>
</eAnnotations>
</eClassifiers>
<eClassifiers xsi:type="ecore:EEnum" name="ArithmeticOperator">
<eAnnotations
</eAnnotations>
<eLiterals name="plus"/>
<eLiterals name="minus" value="1"/>
<eLiterals name="multiply" value="2"/>
<eLiterals name="divide" value="3"/>
</eClassifiers>
<eClassifiers xsi:type="ecore:EDataType" name="ArithmeticOperatorObject"
instanceClassName="org.eclipse.emf.common.util.Enumerator">
<eAnnotations
<details key="name" value="arithmetic-operator:Object"/>
<details key="baseType" value="arithmetic-operator"/>
</eAnnotations>
</eClassifiers>
<eClassifiers xsi:type="ecore:EClass" name="BagExpressionType">
<eAnnotations
<details key="name" value="bag-expression_._type"/>
</eAnnotations>
<eStructuralFeatures xsi:type="ecore:EReference" name="bag"
eType="#//BagType"
<eAnnotations
<details key="name" value="bag"/>
</eAnnotations>
name="bagExpressionUnary" eType="#//BagExpressionUnaryType"
<eAnnotations
<details key="name" value="bag-expression-unary"/>
</eAnnotations>
name="expressionBinary" eType="#//ExpressionBinaryType"
<eAnnotations
<details key="name" value="expression-binary"/>
</eAnnotations>
</eClassifiers>
<eClassifiers xsi:type="ecore:EClass" name="BagExpressionUnaryType">
<eAnnotations
<details key="name" value="bag-expression-unary_._type"/>
</eAnnotations>
name="bagOperatorUnary" lowerBound="1"
eType="#//BagOperatorUnary" defaultValueLiteral="cardinality"
unsettable="true">
<eAnnotations
<details key="name" value="bag-operator-unary"/>
</eAnnotations>
<eStructuralFeatures xsi:type="ecore:EReference" name="bagExpression"
lowerBound="1"
eType="#//BagExpressionType" containment="true"
<eAnnotations
<details key="name" value="bag-expression"/>
</eAnnotations>
</eClassifiers>
<eClassifiers xsi:type="ecore:EClass" name="BagOfType">
<eAnnotations
<details key="name" value="bag-of_._type"/>
</eAnnotations>
<eStructuralFeatures xsi:type="ecore:EAttribute" name="builtinType"
eType="#//BuiltinType"
defaultValueLiteral="integer" unsettable="true">
<eAnnotations
<details key="name" value="builtin-type"/>
</eAnnotations>
<eStructuralFeatures xsi:type="ecore:EReference" name="type"
eType="#//Type" resolveProxies="false">
<eAnnotations
<details key="name" value="type"/>
</eAnnotations>
eType="#//BagType"
<eAnnotations
</eAnnotations>
</eClassifiers>
<eClassifiers xsi:type="ecore:EDataType" name="BagOperator"
<eAnnotations
<details key="name" value="bag-operator"/>
<details key="memberTypes" value="bag-operator-binary
</eAnnotations>
</eClassifiers>
<eClassifiers xsi:type="ecore:EEnum" name="BagOperatorBinary">
<eAnnotations
<details key="name" value="bag-operator-binary"/>
</eAnnotations>
<eLiterals name="intersection"/>
<eLiterals name="multiplicity" value="1"/>
<eLiterals name="addElement" value="2" literal="add_element"/>
<eLiterals name="deleteElement" value="3" literal="delete_element"/>
</eClassifiers>
<eClassifiers xsi:type="ecore:EDataType" name="BagOperatorBinaryObject"
<eAnnotations
<details key="name" value="bag-operator-binary:Object"/>
<details key="baseType" value="bag-operator-binary"/>
</eAnnotations>
</eClassifiers>
<eClassifiers xsi:type="ecore:EEnum" name="BagOperatorUnary">
<eAnnotations
</eAnnotations>
<eLiterals name="cardinality"/>
</eClassifiers>
<eClassifiers xsi:type="ecore:EDataType" name="BagOperatorUnaryObject"
<eAnnotations
<details key="name" value="bag-operator-unary:Object"/>
<details key="baseType" value="bag-operator-unary"/>
</eAnnotations>
</eClassifiers>
<eClassifiers xsi:type="ecore:EClass" name="BagType">
<eAnnotations
<details key="name" value="bag_._type"/>
</eAnnotations>
<eStructuralFeatures xsi:type="ecore:EReference" name="bagElement"
lowerBound="1"
upperBound="-1" eType="#//ListElement" containment="true"
<eAnnotations
<details key="name" value="bag-element"/>
</eAnnotations>
</eClassifiers>
<eClassifiers xsi:type="ecore:EClass" name="BasicTypesType">
<eAnnotations
<details key="name" value="basic-types_._type"/>
</eAnnotations>
<eStructuralFeatures xsi:type="ecore:EAttribute" name="name"
unique="false" lowerBound="1"
upperBound="-1" eType="#//AllowedString">
<eAnnotations
<details key="name" value="name"/>
</eAnnotations>
</eClassifiers>
<eClassifiers xsi:type="ecore:EClass" name="BinaryType">
<eAnnotations
<details key="name" value="binary_._type"/>
</eAnnotations>
<eAnnotations
</eAnnotations>
<eStructuralFeatures xsi:type="ecore:EAttribute" name="operator"
lowerBound="1"
eType="#//OperatorBinary" defaultValueLiteral="concat"
unsettable="true">
<eAnnotations
<details key="name" value="operator"/>
</eAnnotations>
name="expressionBinary" lowerBound="1"
eType="#//ExpressionBinaryType" containment="true"
<eAnnotations
</eAnnotations>
</eClassifiers>
<eClassifiers xsi:type="ecore:EClass" name="BodyType">
<eAnnotations
<details key="name" value="body_._type"/>
</eAnnotations>
<eStructuralFeatures xsi:type="ecore:EReference" name="expression"
lowerBound="1"
eType="#//ExpressionType" containment="true"
<eAnnotations
<details key="name" value="expression"/>
</eAnnotations>
name="booleanOperator" lowerBound="1"
eType="#//BooleanOperator" defaultValueLiteral="&&"
unsettable="true">
<eAnnotations
<details key="name" value="boolean-operator"/>
</eAnnotations>
<eStructuralFeatures xsi:type="ecore:EReference" name="where"
lowerBound="1" eType="#//WhereType"
<eAnnotations
<details key="name" value="where"/>
</eAnnotations>
</eClassifiers>
<eClassifiers xsi:type="ecore:EDataType" name="Boolean"
instanceClassName="boolean">
<eAnnotations
<details key="name" value="boolean"/>
value="http://www.eclipse.org/emf/2003/XMLType#boolean"/>
</eAnnotations>
</eClassifiers>
name="BooleanCollectionExpressionBinaryType">
<eAnnotations
<details key="name"
value="boolean-collection-expression-binary_._type"/>
</eAnnotations>
name="collectionElement" lowerBound="1"
eType="#//ListElement" containment="true" resolveProxies="false">
<eAnnotations
<details key="name" value="collection-element"/>
</eAnnotations>
name="booleanCollectionOperatorBinary"
lowerBound="1" eType="#//BooleanCollectionOperatorBinary"
defaultValueLiteral="union"
unsettable="true">
<eAnnotations
<details key="name" value="boolean-collection-operator-binary"/>
</eAnnotations>
<eStructuralFeatures xsi:type="ecore:EReference" name="collection"
lowerBound="1"
eType="#//CollectionType" containment="true"
<eAnnotations
<details key="name" value="collection"/>
</eAnnotations>
</eClassifiers>
name="BooleanCollectionExpressionUnaryType">
<eAnnotations
<details key="name"
value="boolean-collection-expression-unary_._type"/>
</eAnnotations>
name="booleanCollectionOperatorUnary"
lowerBound="1" eType="#//BooleanCollectionOperatorUnary"
defaultValueLiteral="is_empty"
unsettable="true">
<eAnnotations
<details key="name" value="boolean-collection-operator-unary"/>
</eAnnotations>
lowerBound="1"
<eAnnotations
</eAnnotations>
</eClassifiers>
name="BooleanCollectionOperatorBinary">
<eAnnotations
</eAnnotations>
<eLiterals name="union"/>
<eLiterals name="belongs" value="1"/>
<eLiterals name="notBelongs" value="2" literal="not_belongs"/>
</eClassifiers>
name="BooleanCollectionOperatorBinaryObject"
<eAnnotations
<details key="name"
value="boolean-collection-operator-binary:Object"/>
<details key="baseType" value="boolean-collection-operator-binary"/>
</eAnnotations>
</eClassifiers>
name="BooleanCollectionOperatorUnary">
<eAnnotations
</eAnnotations>
<eLiterals name="isEmpty" literal="is_empty"/>
<eLiterals name="notEmpty" value="1" literal="not_empty"/>
</eClassifiers>
name="BooleanCollectionOperatorUnaryObject"
<eAnnotations
<details key="name"
value="boolean-collection-operator-unary:Object"/>
<details key="baseType" value="boolean-collection-operator-unary"/>
</eAnnotations>
</eClassifiers>
<eClassifiers xsi:type="ecore:EEnum" name="BooleanComparator">
<eAnnotations
<details key="name" value="boolean-comparator"/>
</eAnnotations>
<eLiterals name="gt"/>
<eLiterals name="lt" value="1"/>
<eLiterals name="gtequal" value="2"/>
<eLiterals name="ltequal" value="3"/>
<eLiterals name="equals" value="4"/>
<eLiterals name="notEqual" value="5" literal="not_equal"/>
<eLiterals name="belongs" value="6"/>
</eClassifiers>
<eClassifiers xsi:type="ecore:EDataType" name="BooleanComparatorObject"
<eAnnotations
<details key="name" value="boolean-comparator:Object"/>
<details key="baseType" value="boolean-comparator"/>
</eAnnotations>
</eClassifiers>
name="BooleanExpressionComparisonType">
<eAnnotations
<details key="name" value="boolean-expression-comparison_._type"/>
</eAnnotations>
<eStructuralFeatures xsi:type="ecore:EReference" name="identifier"
lowerBound="1"
eType="#//IdentifierType" containment="true"
<eAnnotations
<details key="name" value="identifier"/>
</eAnnotations>
name="booleanComparator" lowerBound="1"
eType="#//BooleanComparator" defaultValueLiteral="gt"
unsettable="true">
<eAnnotations
</eAnnotations>
<eStructuralFeatures xsi:type="ecore:EReference" name="identifier1"
lowerBound="1"
<eAnnotations
</eAnnotations>
</eClassifiers>
<eClassifiers xsi:type="ecore:EClass" name="BooleanExpressionType">
<eAnnotations
<details key="name" value="boolean-expression_._type"/>
</eAnnotations>
<eStructuralFeatures xsi:type="ecore:EReference" name="term"
eType="#//TermType"
<eAnnotations
<details key="name" value="term"/>
</eAnnotations>
name="booleanCollectionExpressionBinary"
eType="#//BooleanCollectionExpressionBinaryType"
<eAnnotations
<details key="name" value="boolean-collection-expression-binary"/>
</eAnnotations>
name="booleanCollectionExpressionUnary"
eType="#//BooleanCollectionExpressionUnaryType" containment="true"
<eAnnotations
<details key="name" value="boolean-collection-expression-unary"/>
</eAnnotations>
name="booleanExpressionComparison"
eType="#//BooleanExpressionComparisonType" containment="true"
<eAnnotations
<details key="name" value="boolean-expression-comparison"/>
</eAnnotations>
</eClassifiers>
<eClassifiers xsi:type="ecore:EClass" name="BooleanExpressionUnaryType">
<eAnnotations
<details key="name" value="boolean-expression-unary_._type"/>
</eAnnotations>
lowerBound="1"
<eAnnotations
</eAnnotations>
</eClassifiers>
<eClassifiers xsi:type="ecore:EDataType" name="BooleanObject"
instanceClassName="java.lang.Boolean">
<eAnnotations
<details key="name" value="boolean:Object"/>
<details key="baseType" value="boolean"/>
</eAnnotations>
</eClassifiers>
<eClassifiers xsi:type="ecore:EEnum" name="BooleanOperator">
<eAnnotations
</eAnnotations>
<eLiterals name="_" literal="&&"/>
<eLiterals name="_1" value="1" literal="||"/>
</eClassifiers>
<eClassifiers xsi:type="ecore:EDataType" name="BooleanOperatorObject"
<eAnnotations
<details key="name" value="boolean-operator:Object"/>
<details key="baseType" value="boolean-operator"/>
</eAnnotations>
</eClassifiers>
<eClassifiers xsi:type="ecore:EEnum" name="BuiltinType">
<eAnnotations
</eAnnotations>
<eLiterals name="integer"/>
<eLiterals name="natural0" value="1"/>
<eLiterals name="natural" value="2"/>
<eLiterals name="real" value="3"/>
<eLiterals name="char" value="4"/>
<eLiterals name="boolean" value="5"/>
<eLiterals name="true" value="6"/>
<eLiterals name="false" value="7"/>
</eClassifiers>
<eClassifiers xsi:type="ecore:EClass" name="BuiltinType1">
<eAnnotations
<details key="name" value="builtin_._type"/>
</eAnnotations>
<eStructuralFeatures xsi:type="ecore:EAttribute" name="integer"
eType="#//Integer">
<eAnnotations
<details key="name" value="integer"/>
</eAnnotations>
<eStructuralFeatures xsi:type="ecore:EAttribute" name="natural0"
eType="#//Natural0">
<eAnnotations
<details key="name" value="natural0"/>
</eAnnotations>
<eStructuralFeatures xsi:type="ecore:EAttribute" name="natural"
eType="#//Natural">
<eAnnotations
<details key="name" value="natural"/>
</eAnnotations>
<eStructuralFeatures xsi:type="ecore:EAttribute" name="real"
eType="#//Real">
<eAnnotations
<details key="name" value="real"/>
</eAnnotations>
<eStructuralFeatures xsi:type="ecore:EAttribute" name="boolean"
eType="#//Boolean"
unsettable="true">
<eAnnotations
</eAnnotations>
<eStructuralFeatures xsi:type="ecore:EAttribute" name="true"
eType="#//True">
<eAnnotations
<details key="name" value="true"/>
</eAnnotations>
<eStructuralFeatures xsi:type="ecore:EAttribute" name="false"
eType="#//False">
<eAnnotations
<details key="name" value="false"/>
</eAnnotations>
<eStructuralFeatures xsi:type="ecore:EAttribute" name="char"
eType="#//Char">
<eAnnotations
<details key="name" value="char"/>
</eAnnotations>
</eClassifiers>
<eClassifiers xsi:type="ecore:EDataType" name="BuiltinTypeObject"
<eAnnotations
<details key="name" value="builtin-type:Object"/>
<details key="baseType" value="builtin-type"/>
</eAnnotations>
</eClassifiers>
<eClassifiers xsi:type="ecore:EDataType" name="Char"
<eAnnotations
<details key="length" value="1"/>
</eAnnotations>
</eClassifiers>
<eClassifiers xsi:type="ecore:EClass" name="CollectionType">
<eAnnotations
<details key="name" value="collection_._type"/>
</eAnnotations>
<eStructuralFeatures xsi:type="ecore:EReference" name="sequence"
eType="#//SequenceType"
<eAnnotations
<details key="name" value="sequence"/>
</eAnnotations>
<eStructuralFeatures xsi:type="ecore:EReference" name="set"
eType="#//Set" containment="true"
<eAnnotations
<details key="name" value="set"/>
</eAnnotations>
eType="#//BagType"
<eAnnotations
</eAnnotations>
<eStructuralFeatures xsi:type="ecore:EAttribute" name="variable"
<eAnnotations
<details key="name" value="variable"/>
</eAnnotations>
<eAnnotations
</eAnnotations>
<eStructuralFeatures xsi:type="ecore:EReference" name="basicTypes"
eType="#//BasicTypesType"
<eAnnotations
<details key="name" value="basic-types"/>
</eAnnotations>
</eClassifiers>
<eClassifiers xsi:type="ecore:EClass" name="CompoundExpressionType">
<eAnnotations
<details key="name" value="compound-expression_._type"/>
</eAnnotations>
name="booleanExpression" lowerBound="1"
eType="#//BooleanExpressionType" containment="true"
<eAnnotations
<details key="name" value="boolean-expression"/>
</eAnnotations>
unsettable="true">
<eAnnotations
</eAnnotations>
<eStructuralFeatures xsi:type="ecore:EReference" name="condition"
lowerBound="1"
eType="#//ConditionType" containment="true" resolveProxies="false">
<eAnnotations
<details key="name" value="condition"/>
</eAnnotations>
</eClassifiers>
<eClassifiers xsi:type="ecore:EClass" name="ConditionType">
<eAnnotations
sou
FUDForum. Page generated in 0.04657 seconds
