Home » Eclipse Projects » Eclipse Platform » "Completing installation" each time eclipse is started up
"Completing installation" each time eclipse is started up [message #144313] Wed, 15 October 2003 08:31 Go to next message
Originally posted by: tcn.spamgourmet.com
Hi!
I deleted M3's ~/workspace, ~/.eclipse* and eclipse/ and setup M4. But still
I do have the problem that every time I startup eclipse that "Please
wait ... completing installation" popup comes up.
Why??
Re: "Completing installation" each time eclipse is started up [message #144340 is a reply to message #144313] Wed, 15 October 2003 09:42 Go to previous messageGo to next message
Does it come up once or twice?
Peter
Timo Nentwig wrote:
> Hi!
> Why??
Re: "Completing installation" each time eclipse is started up [message #144445 is a reply to message #144340] Wed, 15 October 2003 11:21 Go to previous messageGo to next message
Once. But (with my previous M3 build) I also experienced it one time that it
came up twice. And: the splash screen does not appear. The popup stays open
until the workbench appears.
Re: "Completing installation" each time eclipse is started up [message #144572 is a reply to message #144445] Wed, 15 October 2003 14:37 Go to previous messageGo to next message
For some reason it can't find the "real" splash screen. The default
splash screen is the completing the install screen. When it comes up
twice it is checking the configuration. How did you install it? Its
proabably best if you unzipped into a new directory.
Peter
Re: "Completing installation" each time eclipse is started up [message #144581 is a reply to message #144572] Wed, 15 October 2003 15:06 Go to previous messageGo to next message
This already was a fresh new M4 install/unzip; so I deleted my old eclipse
directory, ~/.eclipse* and even ~/workspace, extracted the archive and
started eclipse....
Re: "Completing installation" each time eclipse is started up [message #146148 is a reply to message #144572] Sat, 18 October 2003 07:43 Go to previous message
>> it came up twice. And: the splash screen does not appear. The popup stays
>> open until the workbench appears.
It now even happens to my run-time workbench. I'm writing on a plugin right
now and already had opened and closed rt workbench for dozens of times.
Then two seconds ago I closed it, opened it, the Please Wait splash screen
appears and none of my plugins are available no more.
I did nothing but closing and reopening it...
TImo
Previous Topic:Properties view refresh
Next Topic:SWTException: Invalid thread access
Current Time: Tue Apr 29 02:51:30 EDT 2025
Powered by FUDForum. Page generated in 0.31410 seconds
