Home » Eclipse Projects » Eclipse Platform » <toc label=".."> with <anchor> and <link_to>
<toc label=".."> with <anchor> and <link_to> [message #144058] Tue, 14 October 2003 18:38 Go to next message
Originally posted by: dcramer.motive.com
If I have two plugins and do the following, I'll end up with:
Test wrapper
Intefaces
File List
foo.h
foo.idl
Intefaces
File List
bar.h
bar.idl
Instead, I want to have the following:
Test wrapper
The foo component api documentation
Intefaces
File List
foo.h
foo.idl
The bar component api documentation
Intefaces
File List
bar.h
bar.idl
I would prefer NOT to put a extra topic element in the tocs like so: <toc
label="The foo component api documentation"
link_to="/testwrapper/toc.xml#anchor_id"><topic label="The foo component
api documentation"><topic href="index.html" label="Interfaces"/>...
because I may also want to use this plugins in contexts where I make the
toc top down, and it would create an unneeded toc level.
Is that possible?
David
toc.xml for wrapper:
<?xml version="1.0" encoding="utf-8"?>
<toc label="Test wrapper">
<anchor id="anchor_id"/>
</toc>
toc.xml for item in wrapper:
<toc label="The foo component api documentation"
<topic href="files.html" label="File List">
<topic href="foo.h.html" label="foo.h"/>
<topic href="foo.idl.html" label="foo.idl"/>
</topic>
<!-- lots of other topics here -->
</toc>
toc.xml for another item in wrapper:
<toc label="The bar component api documentation"
<topic href="bar.h.html" label="bar.h"/>
</topic>
</toc>
Re: <toc label=".."> with <anchor> and <link_to> [message #144378 is a reply to message #144058] Wed, 15 October 2003 14:31 Go to previous messageGo to next message
Konrad Kolosowski is currently offline Konrad KolosowskiFriend
It is not clear which plug-in or TOCs you want to reuse. Assuming you want
to reuse TOCs for items, and not the wrapper, you can put the extra topic
level into the wrapper TOC as in:
<topic label="The foo component api documentation">
<anchor id="anchor_id1"/>
</topic>
<topic label="The bar component api documentation">
<anchor id="anchor_id2"/>
</topic>
</toc>
If you wanted to reuse all three TOCs in different scenarios, you could
introduce a fourth TOC, that would act as a glue just for this scenario.
The TOC can contain the extra topic level and link to wrapper TOC on one
side and item TOCs on another.
Konrad Kolosowski
"David Cramer" <dcramer@motive.com> wrote in message
news:bmhfrh$6p4$1@eclipse.org...
> Test wrapper
> Intefaces
> File List
> foo.h
> foo.idl
> Intefaces
> File List
> bar.h
> bar.idl
> Test wrapper
> Intefaces
> File List
> foo.h
> foo.idl
> Intefaces
> File List
> bar.h
> bar.idl
> Is that possible?
> David
> </toc>
> </topic>
> </toc>
> </topic>
> </toc>
Re: <toc label=".."> with <anchor> and <link_to> [message #146001 is a reply to message #144378] Fri, 17 October 2003 20:30 Go to previous messageGo to next message
In this case, I want to have a single <anchor> that receives many plugins.
The
<toc label="Big Book of Components">
<topic label="High level overview of components" href="overviewpt1.html>
<!-- Lots of topics in here -->
<!-- providing high level overview of the system -->
</topic>
<topic label="Component Documentation">
<!-- A large (indeterminant) number of components' api docs point to
this single anchor point. I wanted to avoid repeating the label for each
one here because the label is already definined in each plugin's toc,
which is generated by a api doc generating tool at build time. -->
</topic>
</toc>
I get the impression that it is atypical or outside the bounds of the way
the toc was designed. I think it's good that you can define the label that
an included toc receives (as the current system allows), but if you are
content to use the label on the <toc> element in that toc, it would be
nice to be able to do so. Does what I'm trying to do make sense? I realize
that I'm having trouble articulating it.
David
> </topic>
> </topic>
> </toc>
> Konrad Kolosowski
> > Test wrapper
> > Intefaces
> > File List
> > foo.h
> > foo.idl
> > Intefaces
> > File List
> > bar.h
> > bar.idl
> > Test wrapper
> > Intefaces
> > File List
> > foo.h
> > foo.idl
> > Intefaces
> > File List
> > bar.h
> > bar.idl
> > Is that possible?
> > Thanks,
> > David
> > </toc>
> > </topic>
> > </toc>
> > </topic>
> > </toc>
Re: <toc label=".."> with <anchor> and <link_to> [message #147431 is a reply to message #146001] Tue, 21 October 2003 19:25 Go to previous messageGo to next message
toc.xml for wrapper (primary), in a product:
</topic>
</topic>
</toc>
footoc.xml for wrapper (primary), in a product that has toc.xml, but will
work separately as well:
<toc label="Foo Component Documentation">
</toc>
footocglue.xml for wrapper (NOT primary), shipped always together with
footoc.xml, will not do anything if toc.xml not present:
<toc label="Foo Component Documentation Glue"
link_to="/wrapper/toc.xml#anchor_id" >
<topic label="Foo Component API Documentation">
<link href="tocfoo.xml" />
</topic>
</toc>
Will not footocglue.xml do what you need? It ads a topic level only when
you need it.
Konrad Kolosowski
news:bmpjh0$mof$1@eclipse.org...
> The
> </topic>
> </topic>
> </toc>
> David
want
topic
> > </topic>
> > </topic>
> > </toc>
> > Konrad Kolosowski
> > > Test wrapper
> > > Intefaces
> > > File List
> > > foo.h
> > > foo.idl
> > > Intefaces
> > > File List
> > > bar.h
> > > bar.idl
> > > Test wrapper
> > > Intefaces
> > > File List
> > > foo.h
> > > foo.idl
> > > Intefaces
> > > File List
> > > bar.h
> > > bar.idl
<toc
component
the
> > > Is that possible?
> > > Thanks,
> > > David
> > > </toc>
> > > </topic>
> > > </toc>
> > > </topic>
> > > </toc>
Re: <toc label=".."> with <anchor> and <link_to> [message #148794 is a reply to message #147431] Thu, 23 October 2003 21:46 Go to previous message
Perfect.
In footocglue.xml, you meant <link toc="footoc.xml" />, of course.
Works beautifully.
Thanks!!
David
> </topic>
> </topic>
> </toc>
> </toc>
> </topic>
> </toc>
> you need it.
> Konrad Kolosowski
> > The
> > </topic>
> > </topic>
> > </toc>
> > Thanks,
> > David
Previous Topic:Simple Dialog Question
Next Topic:Linking resources
Current Time: Thu Aug 29 12:55:33 GMT 2024
Powered by FUDForum. Page generated in 0.04692 seconds
