Home » Eclipse Projects » Eclipse Platform » Eclipse install can't find bootstrap code
Eclipse install can't find bootstrap code [message #143356] Mon, 13 October 2003 22:49 Go to next message
Originally posted by: j_bfowler.sympatico.ca
After installing the latest SDK from Sun(j2sdk-1_4_2_01), eclipse fails to
start. The content of the log file is:
!SESSION
!ENTRY org.eclipse.core.launcher 4 0 Oct 13, 2003 22:23:42.718
!MESSAGE Exception launching the Eclipse Platform:
!STACK
java.lang.RuntimeException: Could not find bootstrap code. Check location
of boot plug-in or specify -boot.
at org.eclipse.core.launcher.Main.searchForBoot(Main.java:468)
at org.eclipse.core.launcher.Main.getBootPath(Main.java:438)
at org.eclipse.core.launcher.Main.basicRun(Main.java:281)
at org.eclipse.core.launcher.Main.run(Main.java:747)
at org.eclipse.core.launcher.Main.main(Main.java:583)
Removing the last SDK install, and reinstalling Eclipse does not fix.
Looking at other forum entries for the same error, I now start Eclipse
with explicite locations of -data and -vm
also I have c:\eclipse\startup.jar in the classpath and included the
eclipse\plugin directory in the classpath, but still get the error.
Re: Eclipse install can't find bootstrap code [message #144630 is a reply to message #143356] Wed, 15 October 2003 16:33 Go to previous message
JimF wrote:
Ok, found the problem. It was the directory structure of the eclipse files
as noted in the bug report / fix here:
http://bugs.eclipse.org/bugs/show_bug.cgi?id=35718
Previous Topic:using colors/styles with JFace
Next Topic:[ANN] CodePro WebCast Thursday 1:00pm EDT
Current Time: Fri Apr 25 01:29:30 EDT 2025
Powered by FUDForum. Page generated in 0.02386 seconds
