Compatibility GMF1.0.3 / GMF2.0 [message #143311] |
Wed, 18 July 2007 15:28 |
Originally posted by: Halimatou.Pouye-Diaw.thomson.net
Hi, everybody
I worked on a model with GMF 1.0.3. which contains for example some
compartments (a node X can contain many nodes X recursively). It works
fine.
I migrated to GMF 2.0 and I no longer can add a node X in the editor.
The compatibility GMF1.0.3 / GMF2.0 is not ensured?
Thanks for any reply.
Lima.
Re: Compatibility GMF1.0.3 / GMF2.0 [message #143386 is a reply to message #143326] |
Thu, 19 July 2007 08:17 |
Hi, Andrew
Thank you for your reply.
Yes effectively, I used the "Migrate to GMF 2.0" action for the GMF graph,
the GMF map and I regenerated the GMF gen.
I can't understand why a model working with GMF1.0.3 doesn't work with
GMF2.0.
Lima.
FUDForum. Page generated in 0.03428 seconds
