Home » Language IDEs » ServerTools (WTP) » XML Editor
XML Editor [message #143305] Wed, 12 October 2005 13:30 Go to next message
I'm new in plugins development, simple question - how can i run wtp xml
editor with selected file form my plugin, i must extend them?
Robert
Re: XML Editor [message #143357 is a reply to message #143305] Thu, 13 October 2005 00:52 Go to previous messageGo to next message
On Wed, 12 Oct 2005 13:30:16 -0400, robert w=C4=85s <rwas8@gazeta.pl> wr=
ote:
> I'm new in plugins development, simple question - how can i run wtp xm=
l
> Robert
Do you mean you have special extension, such as filename.was :)
..... you need to tell Eclipse that you want ".was" considered
as "XML Content Type" ... where's a way under user prefrences.
If you wanted to do in plugin, you can use the contentType
extension point to "add" your extension to the 'org.eclipse.core.runtime=
..xml'
content type.
Re: XML Editor [message #143505 is a reply to message #143357] Thu, 13 October 2005 14:12 Go to previous messageGo to next message
Originally posted by: amywu.us.DELETETHISPART.ibm.com
FYI, the User preference is in Preferences:
General --> Content Types
"David Williams" <david_williams@us.ibm.com> wrote in message
news:op.sykihftjac05ss@dmw2t23.mshome.net...
> Robert
'org.eclipse.core.runtime.xml'
content type.
Re: XML Editor [message #143582 is a reply to message #143505] Fri, 14 October 2005 03:20 Go to previous messageGo to next message
I know how asociate xml content by user interface or in plugin.
Generally i have problem how run any editor with file *.xml.
I have File (java.io.File) which path is decodedd from page browsed in
swt browser and i want open it with xml editor programatically of
course. I thing that have elementary problem.
>>Robert
> content type.
Re: XML Editor [message #143879 is a reply to message #143582] Fri, 14 October 2005 11:28 Go to previous message
To programatically open a java.io.File in the xml editor, you could use one
of the IDE.openEditor methods. The problem is you need an IFile as input,
not java.io.File.
If your file is in your eclipse workspace, you can try something like the
following to get the IFile:
IFile file = null;
IFile[] files =
ResourcesPlugin.getWorkspace().getRoot().findFilesForLocatio n(new
Path(javaFile.getSystemPath()));
for (int i = 0; i < files.length && file == null; i++)
if (files[i].exists())
file = files[i];
Once you have the IFile, you can do something like the following:
IWorkbenchPage page =
PlatformUI.getWorkbench().getActiveWorkbenchWindow().getActi vePage();
IEditorPart editor = IDE.openEditor(page, file, true);
This will open the editor in the default editor registered for the file's
content type.
If your file is not in your workspace, you should check out
org.eclipse.wst.html.ui.internal.hyperlink.ExternalFileHyper link
That class wraps a file in an IEditorInput and then calls openEditor.
Hope that helps!
"robert w
Previous Topic:SDO/EMF -> WS
Next Topic:Flakiness of web services tools
Current Time: Wed Sep 17 01:29:57 EDT 2025
Powered by FUDForum. Page generated in 0.03691 seconds
