Re: processType for C/C++ Local Application launch config [message #143221 is a reply to message #143211] |
Wed, 13 April 2005 17:31 |
Originally posted by: mikhailk.qnx.com
You're right the CDT doesn't set ATTR_PROCESS_TYPE. Please, submit an
enhancement request to the cdt-launch component.
"Richard Miskin" <richard.miskin@ipl.com> wrote in message
news:f5341d7981001eadd83b1f360e433c40$1@www.eclipse.org...
> I'm attempting to make use of the org.eclipse.debug.ui.consoleLineTrackers
> extension point to parse the output from running a 'C/C++ Local
> Application'. I can get this to work for a Java app by using:
> <extension
> point="org.eclipse.debug.ui.consoleLineTrackers">
> <consoleLineTracker
> id="com.ipl.products.cantpp.eclipse.parsers.outputparser"
> class="com.ipl.products.cantpp.eclipse.parsers.OutputParser "
> processType="java">
> </consoleLineTracker>
> </extension>
> Unfortunately CDT doesn't appear to set ATTR_PROCESS_TYPE when it creates
> a process so I'm not able to specify an appropriate processType.
> Can someone confirm if I'm correct, or tell me what the correct
> processType would be?
> Cheers,
> Richard
FUDForum. Page generated in 0.02957 seconds
