Creating a VM instance programatically [message #143197] |
Wed, 18 February 2004 23:32 |
Originally posted by: handcock.redhat.com
Does anyone know how to create an installed VM definition programatically?
ie. I 'm trying to add a JVM at /foo/bar/java_home to the Eclipse
preferences using Eclipse API calls.
Jeremy
Re: Creating a VM instance programatically [message #144065 is a reply to message #143325] |
Fri, 20 February 2004 17:08 |
Darin Wright wrote:
> Create an instance of a VMStandin, set its properties/attributes, and then
> call "convertToRealVM". This will add it to the JRE definitions.
Thanks, Darin.
I'm somewhat of an eclipse newbie. This snippet doesn't seem to be
working for me:
StandardVMType stdvmtype = new StandardVMType();
VMStandin standin = new VMStandin(stdvmtype, "someUniqueID");
standin.setInstallLocation(new File("/opt/IBMJava2-141"));
standin.setName("IBMJava2-141");
IVMInstall realVM = standin.convertToRealVM();
try {
JavaRuntime.setDefaultVMInstall(realVM, null, true);
} catch(Exception e) {
e.printStackTrace();
Whenever I try to setDefaultVMInstall, I get a NPE at
org.eclipse.jdt.internal.launching.CompositeId.toString(Comp ositeId.java:42).
Are there additional things that I need to define in the VMStandin before
calling convertToRealVM()?
Thanks.
Jeremy
> "Jeremy Handcock" <handcock@redhat.com> wrote in message
> news:c10smj$5km$1@eclipse.org...
> > Thanks,
> > Jeremy
Re: Creating a VM instance programatically [message #144643 is a reply to message #144065] |
Mon, 23 February 2004 14:29 |
Darin Wright Messages: 454 Registered: July 2009 |
You should not create an instance of "StandardVMType", you should retrieve
it from the launching plug-in
JavaRuntime.getVMInstallType(String id).
The id for a standard VM type is
"org.eclipse.jdt.internal.debug.ui.launcher.StandardVMType".
Darin
news:c15eu6$c93$1@eclipse.org...
then
> Thanks, Darin.
> working for me:
> try {
> Thanks.
> Jeremy
programatically?
> > > Thanks,
> > > Jeremy
Re: Creating a VM instance programatically [message #144688 is a reply to message #144643] |
Mon, 23 February 2004 15:42 |
Ah, I see. Excellent... got this to work now. Thanks for your help, Darin.
Jeremy
> Darin
> then
>>Thanks, Darin.
>>working for me:
>>try {
>>Thanks.
>>Jeremy
> programatically?
>>>>Thanks,
>>>>Jeremy
FUDForum. Page generated in 0.04398 seconds
