Eclipse 3.1M6/CDT I200504120301 indexer problem [message #143170] |
Wed, 13 April 2005 06:46 |
Originally posted by: d98_ama.hotmail.com
It seems like the indexer is doing a full "rebuild" every time I start
Eclipse. It is quite annoying since it takes at least 30 minutes.
Has any one else seen this? Any hints on where I can look to find out why
this occurs (I've just started to use CDT)??
/Anders
Re: Eclipse 3.1M6/CDT I200504120301 indexer problem [message #143232 is a reply to message #143201] |
Wed, 13 April 2005 18:15 |
Originally posted by: mark_melvin.amis.com
Could this possibly be related to the platform bug I came across here?:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=89965
It sounds different from Bug 91145, but may be the cause of Anders's
issue (however, I know nothing about the internals of the CDT's indexer).
It should be fixed in the latest integration builds - I think. You may
want to check it out and see if this is what causing the indexer to
re-index everything.
Mark.
Bogdan Gheorghe wrote:
> Hi Anders -
> There is a bug for this (Bug# 91145 ) - but we're having a tough time
> reproducing it all times. If you could add the exact steps you took to
> create
> your project (ie. Went to Project Wizrard->Selected Standard C++
> Project->Selected DOM Indexer->Checked Index enabled etc.) that might
> help us track this down.
> Bogdan
> "Anders Magnusson" <d98_ama@hotmail.com> wrote in message
> news:8895a723cb39b0b232fcb079d93156e0$1@www.eclipse.org...
>>Hi,
>>/Anders
Re: Eclipse 3.1M6/CDT I200504120301 indexer problem [message #143254 is a reply to message #143201] |
Thu, 14 April 2005 06:14 |
I don't remeber exactly how I did it. I followed a tutorial on the CDT web
page, and I do remember that it told me to not check the indexer while
creating the project (in the tutorial the indexer was enabled later), but
I did any way.
One thing I noticed now is that I'm using the "Original C/C++ Indexer"
(the project was created with CDT 2.1). Should I switch to the DOM
indexer??
/Anders
FUDForum. Page generated in 0.03671 seconds
