VE with Eclipse 3.3.0 [message #143084] |
Mon, 19 November 2007 21:25 ![Go to next message Go to next message](theme/Solstice/images/down.png) |
P. Michael Hutchins![Friend of Eclipse Friend](/donate/web-api/friends_decorator.php?email=pmh%40draper.com) Messages: 19 Registered: July 2009 |
Junior Member |
I used "Update Manager" the best I could to get VE.
Product Configuration now shows the following:
o Visual Editor SDK 1.2.1.v20060825...
o Java EMF Model SDK 1.2.3.v20070130...
o Visual Editor 1.2.1.v20060817...
o Visual Editor Source 1.2.1.v20060817
I had a problematic RCP patch listed in the larger list. I couldn't
figure out how to get it fixed, so I just disabled & removed it.
The "VE Developer FAQ"
( http://www.eclipse.org/vep/WebContent/faq.html#install_howto) tells how
to get VE for Eclipse 3.1.2 -- and then says "With Eclipse 3.2, there's
Callisto, which makes it all simpler...". Then it says "See Callisto.",
but that URL takes me to a place that is utterly useless to me.
Then it says "Or you can download the version of VE that matches your
installation of Eclipse.", but I didn't find any way to do that matching.
When I run Eclipse -clean -debug, I get the following:
Start VM: -Xms40m
-Xmx512m
-Djava.class.path=C:\eclipse\plugins\org.eclipse.equinox.lau ncher_1.0.1.R33x_v20070828.jar
-os win32
-ws win32
-arch x86
-showsplash
C:\eclipse\\plugins\org.eclipse.platform_3.3.1.M20070725\spl ash.bmp
-launcher C:\eclipse\eclipse.exe
-name Eclipse
--launcher.library
C:\eclipse\plugins\org.eclipse.equinox.launcher.win32.win32. x86_1.0.1.R33x_v20070828\eclipse_1020.dll
-startup
C:\eclipse\plugins\org.eclipse.equinox.launcher_1.0.1.R33x_v 20070828.jar
-clean
-debug
-vm C:\Program Files\Java\jre1.5.0_11\bin\client\jvm.dll
-vmargs
-Xms40m
-Xmx512m
Install location:
file:/c:/eclipse/
Configuration file:
file:/c:/eclipse/configuration/config.ini loaded
Configuration location:
Framework located:
file:/c:/eclipse/plugins/org.eclipse.osgi_3.3.1.R33x_v200708 28.jar
Framework classpath:
Splash location:
Debug options:
file:/C:/eclipse/.options not found
Time to load bundles: 63
Starting application: 5328
Application Started: 14375
Someone said that doing this showed some dependencies that he hadn't known
about.
(although why in the world one would have to go to such an arcane command
line method to find this out, I can't imagine)
I don't see anything like that in my console output.
(The bottom line is that when I try to open a Java file in the Visual
Editor the way that Help sez to..
(right-click the .java-file in the Package Explorer view of theJava
perspective, and select Open With > Visual Editor in the popup menu)
..I can't find Visual Editor anywhere.
(ie: including looking in Other...) )
What should I do, please?
-- M.
Re: VE with Eclipse 3.3.0 [message #143095 is a reply to message #143084] |
Tue, 20 November 2007 13:55 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Originally posted by: luis_dediego.yahoo.com
I also had problems when trying to use VE. It is currently not compatible with the 3.3 release. The best
solution is to install another version of Eclipse with the proper plugin configuration and make the edit using
this release. If you want to go back to the latest development version you can start the first Eclipse but
with VE disabled.
My current configuration is:
Eclipse version 3.2 from Callixto.
and using links to mount eclipse extension I have added
extension.EclipseEMFSDK2.2.0.link
extension.EclipseGEF3.2.link
extension.EclipseVE1.2.2.link
Those are the downloaded versions of the features installed.
If you do not know how to configure Eclipse to be started with a external configurable set of features (using
links) post me a new message for the explanation.
Hope this helps.
Best regards.
Luis de Diego
FUDForum. Page generated in 0.04381 seconds
