Home » Archived » BIRT » BIRT: Help!!!
BIRT: Help!!! [message #143083] Fri, 10 March 2006 16:29 Go to next message
Hi! I'm having problems with the headers and footers from the Master Page.
1. I can't add dynamic elements like tables (i doesn't evaluate them)
2. every static element added there doesn't act as a header or footer in
the version of report viewed in the IE or Mozilla (the elements from the
normal page overlap with the elements from the header). With simple text
elements it works ok, but not with other.
Can anyone have a solution? Thank you alot,
Cristian
Re: BIRT: Help!!! [message #143092 is a reply to message #143083] Fri, 10 March 2006 16:31 Go to previous messageGo to next message
ok. the solution to the problem number 2 is to increase the header.
for problem number one (I can't add dynamic elements like tables (i
doesn't evaluate them)can anyone help me?
Thank you,
Cristian
Re: BIRT: Help!!! [message #143116 is a reply to message #143092] Fri, 10 March 2006 17:31 Go to previous messageGo to next message
Cristian,
BIRT does not support adding Tables dynamically in script. You can do this
using the Design Engine API.
You can also add tables and set their visibility.
Jason Weathersby
BIRT PMC
"Cristian" <ceol.gael@gmail.com> wrote in message
news:33da9ce4ef39a613169dcbb5d95159d1$1@www.eclipse.org...
> Thank you,
> Cristian
Re: BIRT: Help!!! [message #143196 is a reply to message #143116] Sat, 11 March 2006 07:46 Go to previous message
thank you
Previous Topic:Best way to embed BIRT in an RCP
Next Topic:Report Viewer (TOC) with Apache+Tomcat, WinXP
Current Time: Tue Apr 29 01:57:53 EDT 2025
Powered by FUDForum. Page generated in 0.69846 seconds
