Home » Eclipse Projects » GEF » CreationToolEntry and SimpleFactory
CreationToolEntry and SimpleFactory [message #143053] |
Fri, 16 July 2004 20:00 ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Originally posted by: bandrews.bphnx.com
I have added a CreationToolEntry object to my PaletteGroup, like this:
control.add(new CreationToolEntry("Window",
"Create Window",
new SimpleFactory(WindowModel.class),
null,
null);
When I select this tool then click in the viewer, my execute() method of
my CreateCommand gets called, but nothing is drawn in the viewer.
I believe my createEditPart() method of the PartFactory is supposed to be
called by the framework somewhere in here, but where? It does not get
called at all. What could I be doing wrong?
Any help is very much appreciated as my hair is beginning to fall out!
thanks,
B
Re: CreationToolEntry and SimpleFactory [message #143063 is a reply to message #143053] |
Fri, 16 July 2004 21:12 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Originally posted by: webmaster.mafd.org
Barry,
are you "registering" the EditPartFactory with the editor?
This is typically done in "configureGraphicalViewer" method:
getGraphicalViewer().setEditPartFactory(new YourEditPartFactory());
Spack
"Barry Andrews" <bandrews@bphnx.com> wrote in message
news:cd9c4b$kbv$1@eclipse.org...
> "Create Window",
> null,
> null);
> thanks,
> B
Re: CreationToolEntry and SimpleFactory [message #143069 is a reply to message #143063] |
Sat, 17 July 2004 00:09 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Yes, I did do that.
Richard Spackmann wrote:
> Barry,
> Spack
> > "Create Window",
> > null,
> > null);
> > thanks,
> > B
Re: CreationToolEntry and SimpleFactory [message #143079 is a reply to message #143069] |
Sat, 17 July 2004 02:04 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Originally posted by: RichardSpackmann.mafd.org
Hmmm....are you sure your EditPartFactory creates new EditParts of type
WindowModel ?
For example, the factories I have seen from tutorials have if statements
that check for the instance type of iModel.
What do you specifically do in your CreateCommand?
Also, the debugger is INVALUABLE, I recommend stepping through to see what's
not happening. Other than that - I really dont' know, I'm not that much of
an expert.
Maybe post your code so I can dig through and other people can chime in?
Spack
news:cd9qo1$66f$1@eclipse.org...
> Yes, I did do that.
> > Barry,
> > Spack
> > > "Create Window",
> > > new
> > > null,
> > > null);
of
be
> > > thanks,
> > > B
Re: CreationToolEntry and SimpleFactory [message #143364 is a reply to message #143053] |
Mon, 19 July 2004 17:15 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Pratik Shah![Friend of Eclipse Friend](/donate/web-api/friends_decorator.php?email=ppshah%40us.ibm.com) Messages: 1077 Registered: July 2009 |
Once your command creates the new object and adds it to the model, the model
parent should be firing a property change. When its corresponding EditPart
gets notified of the change in children, it should invoke refreshChildren()
(which will create the EditPart for the new child).
> "Create Window",
> null,
> null);
> thanks,
> B
Re: CreationToolEntry and SimpleFactory [message #143575 is a reply to message #143079] |
Tue, 20 July 2004 18:06 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Richard,
I sent you a zip file of the source code since it's too large to put here.
I didn't see a place to attach files, so I hope it's okay that I sent you
the email.
many thanks for your help!
Barry
> WindowModel ?
> an expert.
> Spack
> > Yes, I did do that.
> > > Barry,
> > > Spack
> > > > "Create Window",
> > > > new
> > > > null,
> > > > null);
> of
> be
> > > > thanks,
> > > > B
Re: CreationToolEntry and SimpleFactory [message #143710 is a reply to message #143364] |
Tue, 20 July 2004 19:44 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) |
Thanks! The problem was my "contents" EditPart did not implement a
PropertyChangeListener so it was not receiving notifications on addChild.
> > "Create Window",
> > null,
> > null);
> > thanks,
> > B
Current Time: Wed Jul 17 10:34:55 GMT 2024
Powered by FUDForum. Page generated in 0.04222 seconds
