Home » Language IDEs » Java Development Tools (JDT) » Problem manipulating java source
Problem manipulating java source [message #142929] Wed, 18 February 2004 09:46 Go to next message
I create and manipulate java sources using the provided jdt api's. I replace
text in the buffer of a ICompilationUnit to insert statements. After
replacing the compilation unit gets reconciled using
ICompilationUnit.reconcile(). But if I analyze created or manipulated
methods (got using IType.getMethods() or IType.findMethod(...) ) the source
of the method does not really reflect the changes I've done. The source
IMethod.getSource() is a fragment of the method as defined in the buffer
and contains just my inserted statements and a rest of the method; but that
it seams to me a rather accidental content. Debugging my application
(running on eclipse 2.1.2) I figured out that I'm not allowed to change
something in a workspace operation. But I could not figure out how I really
can make sure or test that the changes I've done in the buffer are
consistent wiith the java model.
Thanks for help.
Stefan
Re: Problem manipulating java source [message #142939 is a reply to message #142929] Wed, 18 February 2004 10:00 Go to previous messageGo to next message
The Java model will be up-to-date at the end of the workbench modifying
operation.
Jerome
"Stefan Holzknecht" <s.holzknecht@intershop.de> wrote in message
news:c0vtd7$ri5$1@eclipse.org...
> Hello,
replace
source
that
really
> Thanks for help.
> Stefan
Re: Problem manipulating java source [message #142947 is a reply to message #142939] Wed, 18 February 2004 10:14 Go to previous messageGo to next message
Hi Jerome,
I do not manipulate the buffer in a workspace operation. And I do not
manipulate resources (the compilation unit is actually a working copy).
Therefore I did expect that the model is up to date after reconciling the
unit.
Stefan
"Jerome Lanneluc" <jerome_lanneluc@fr.ibm.com> wrote in message
news:c0vug8$t9t$1@eclipse.org...
> operation.
> Jerome
> > Hello,
> replace
> source
buffer
> that
> really
> > Thanks for help.
> > Stefan
Re: Problem manipulating java source [message #142967 is a reply to message #142947] Wed, 18 February 2004 10:29 Go to previous message
Your expectation is right. It should be up-to-date after reconcile. Can you
please enter a bug report against JDT Core with steps to reproduce this
problem?
Jerome
news:c0vv19$u58$1@eclipse.org...
> Hi Jerome,
> unit.
> Stefan
> > operation.
> > Jerome
> > > Hello,
> > replace
> > source
source
> buffer
> > that
change
> > really
> > > Thanks for help.
> > > Stefan
Previous Topic:Problems with Classpath Container in Eclipse 3.0 M7
Next Topic:Debug Current Instruction Pointer
Current Time: Sat Nov 01 21:55:47 EDT 2025
Powered by FUDForum. Page generated in 0.07284 seconds
