cvs 1.11.5: "The server did not provide any additional information" [message #142172] |
Mon, 16 February 2004 04:57  |
I see the error message in the subject when I try to do an "compare with
...." against an CVS 1.11.5 on a Solaris 9 Sparc.
It ran fine against CVS 1.11.1p1 on Linux
The log file says:
"!ENTRY org.eclipse.team.cvs.ui 4 0 Feb 16, 2004 10:56:25.765
!MESSAGE The server did not provide any additional information.
!STACK 1
org.eclipse.team.internal.ccvs.core.connection.CVSServerExce ption: The
server reported an error while performing the "cvs log" command.
org.eclipse.team.internal.ccvs.core.resources.RemoteFile.get LogEntries(RemoteFile.java:266)
org.eclipse.team.internal.ccvs.ui.actions.CompareWithRevisio nAction$2.run(CompareWithRevisionAction.java:76)
org.eclipse.team.internal.ccvs.ui.repo.RepositoryManager.run (RepositoryManager.java:809)
org.eclipse.team.internal.ccvs.ui.actions.CVSAction$1.run(CV SAction.java:242)
org.eclipse.jface.operation.ModalContext$ModalContextThread. run(ModalContext.java:101)
!ENTRY org.eclipse.team.cvs.core 4 -10 Feb 16, 2004 10:56:25.765
!MESSAGE The server reported an error while performing the "cvs log"
command.
!SUBENTRY 1 org.eclipse.team.cvs.core 4 -10 Feb 16, 2004 10:56:25.765
!MESSAGE The server did not provide any additional information."
I have the problem both with Eclipse 2.1.2 and Eclipse 3.0 M7.
I found a bug on eclipse.org that there are problems with CVS servers in
Eclipse 2.1.x but not in the 3.0 stream. So it can't be this problem,
can it?
Does anyone have an advice?
Christoph
FUDForum. Page generated in 0.03343 seconds
