Home » Eclipse Projects » JFace » JFace Modeless Dialog
- JFace Modeless Dialog [message #12969] Tue, 09 June 2009 05:33
Thought this can be helpful to anyone who wants to make existing dialogs
as modeless but without breaking any code which assumes that Dialog::open
does not return to caller till the dialog is closed.
package yourpackage;
import org.eclipse.jface.dialogs.Dialog;
import org.eclipse.swt.SWT;
import org.eclipse.swt.widgets.Shell;
* This acts as a modeless dialog. Essentially this has following
characteristics...
* - Lets the user interact with other UI when this dialog is open
* - Call to open() does not return control to the caller till the dialog
is closed by OK/Cancel etc.,
public class ModelessDialog extends Dialog
public ModelessDialog(Shell parentShell) {
super(parentShell);
setBlockOnOpen(false);
protected void setShellStyle(int newShellStyle)
int newstyle = newShellStyle & ~SWT.APPLICATION_MODAL; /* turn off
APPLICATION_MODAL */
newstyle |= SWT.MODELESS; /* turn on MODELESS */
super.setShellStyle(newstyle);
public int open()
int retVal = super.open();
pumpMessages(); /* this will let the caller wait till OK, Cancel is
pressed, but
will let the other GUI responsive */
return retVal;
protected void pumpMessages()
Shell sh = getShell();
Display disp = sh.getDisplay();
while( !sh.isDisposed() ) {
if( !disp.readAndDispatch() ) disp.sleep();
disp.update();
Venkat
Previous Topic:SWTException: Invalid thread access when binding in non-UI thread
Next Topic:WizardDialog, WizardPage Back, Next, Finish, Cancel Event Hooks
Current Time: Tue Apr 29 01:07:13 EDT 2025
Powered by FUDForum. Page generated in 0.27914 seconds
