Getting XDebug plugin to work [message #12960] |
Mon, 09 April 2007 20:53 |
Originally posted by: eduardo.almeida.gmail.com
Im tryng to debug with PDT.. I tried installing the ZendDebugger but there
is no way I can make php read the ZendDebugger.so. I was able to install
Xdebug and I can debug with xdebug-client
I downloaded Kelsey's plugin: "Prebuilt Binary of XDebug With Path Mapper
V0.1.4 (PDT RC2) [.ZIP]" and uncompressed into the features and plugins of
my eclipse.
I created a PHP Script run configuration, if I enable "Run with debug
info" I get the following error:
Debug Error - Session Terminated
The debug session could not be started.
Please make sure that the debugger is properly configured.
If I uncheck the checkbox, it runs fine.
I created a debug run configuration:
There is no way to debug with the CLI php? My part of the project there is
nothing to do with web pages, just the business part of it, so debugging
with cli would be much better.
I launched my webserver, copied the files to my public_html and configured
the run configuration.
Now when I start the debug it prints information in the eclipse internal
browser but it wont stop in any break point I set.
Is there something I have to do?? Thank you!
Eduardo
Re: Getting XDebug plugin to work [message #13018 is a reply to message #12960] |
Tue, 10 April 2007 13:16 |
Oww... I just found that, under Debug, there is a "PHP exe script with
XDebug", now I'm able to debug with Xdebug. But I still can't debug with
the internal browser.
FUDForum. Page generated in 0.07182 seconds
