Home » Archived » Visual Editor (VE) » Updated patched VE for 3.3/Europa
Re: Updated patched VE for 3.3/Europa [message #140734 is a reply to message #140726] |
Thu, 20 September 2007 16:40 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Chris,
I assume you mean EMF 2.3.0. You likely need to run eclipse.exe -clean
to update the configuration. If things still fail, run with -clean
-debug and look at the Error log for clues about what might be failing
to activate and why.
Chris Dolan wrote:
> Philippe,
> Thanks for your efforts! I'm trying out your Sept 12 build, but have not had success. I did the following:
> * unpacked the .zip
> * changed the folder name to "eclipse"
> * created a .eclipseextension file
> * went to Help>Software Updates>Manage Configuration
> * Add an Extension location
> * selected my "eclipse" folder above
> * restarted
> Now I see VE in my plugin list via
> Help>About Eclipse Platform>Plug-in Details
> However, I don't see any of the VE features (Visual class not listed in New... and no Visual Editor option under right-click>Open With...)
> I have GEF 3.2.100.v20070529 and EMF v2.3.9.v200706262000 installed under Eclipse 3.3.0 (not EasyEclipse).
> Any ideas?
Re: Updated patched VE for 3.3/Europa [message #140800 is a reply to message #140790] |
Thu, 20 September 2007 18:45 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Chris,
The log is good for describing problems like missing plugins, so it's a
good idea to look closely at that for clues. I'm sure the log will say
that JEM is missing, for example.
Chris Dolan wrote:
> > Chris,
> > eclipse.exe -clean
> > run with -clean
> > might be failing
> Oh, right, I meant 2.3.0. I did some more digging and it appears my problem is that I lack JEM 2.0.0. I'm currently following Eric's advice ( http://dev.eclipse.org/newslists/news.eclipse.tools.ve/msg07 104.html) and am trying to install the WTP SDK, but it's a confusing process.
Re: Updated patched VE for 3.3/Europa [message #140822 is a reply to message #140800] |
Thu, 20 September 2007 20:34 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Chris Dolan![Friend of Eclipse Friend](/donate/web-api/friends_decorator.php?email=christopher_dolan%40avid.com) Messages: 14 Registered: July 2009 |
Junior Member |
I got it to work once I figured out the JEM stuff. In the end, these are the steps that worked for me. Note: these are likely not the minimal steps, just one working solution.
1) Fully uninstall any old version of VE or JEM (not just disable)
2) via the Europa update site, install prerequisites for WTP:
2a) org.eclipse.datatools
2b) org.eclipse.wst
2c) org.eclipse.jst
2d) org.eclipse.jpt
3) Install the 3.0M1 milestone release of WTP SDK, which is the authoritative source of JEM 2.0.0:
3a) Go to http://download.eclipse.org/webtools/downloads/
3b) Click the 3.0M1 build
3c) Download the wtp-sdk zip
3d) Unpack the .zip file somewhere
3e) In that extracted folder, there is an "eclipse" subdir
3f) In that subdir, create a file called ".eclipseextension"
3g) Put the following three lines in that file:
name=WTP
id=org.eclipse.wst
version=2.0.0.v200706041905
3h) In eclipse, go to Help > Software Updates > Manage Configuration
3i) Click "Add an Extension Location"
3j) Select the WTP "eclipse" subdir from above
4) Install the build of VE:
4a) Go to http://sourceforge.net/project/showfiles.php?group_id=131065 &package_id=154855
4b) Click "Visual Editor patched as in bug 202562"
4c) Click org.eclipse.visualeditor-1.3.0.200709121813.zip
4d) Unpack the .zip file somewhere
4e) In that extracted folder, there is an " org.eclipse.visualeditor-1.3.0.200709121813" subdir
4f) Rename that subdir to "eclipse"
4g) In that "eclipse" subdir, create a file called ".eclipseextension"
4h) Put the following three lines in that file:
name=Visual Editor
id=org.eclipse.visualeditor
version=1.3.0.200709121813
4i) In eclipse, go to Help > Software Updates > Manage Configuration
4j) Click "Add an Extension Location"
4k) Select the VE "eclipse" subdir from above
Re: Updated patched VE for 3.3/Europa [message #140874 is a reply to message #140822] |
Fri, 21 September 2007 12:45 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Chris,
Someone needs to open a request for WTP to provide a feature purely for
JEM. VE should not need to go through all this to pick up JEM! Note
that EMF itself has been decomposed in a large number of small features
so we've already tried to be helpful in this regard. What I'd like to
see for all projects is that they specify a project file set that allows
anyone to extract the components for that project directly from CVS.
We'll try to accomplish this in the modeling project first before we
start pointing fingers at others for not doing this. :-P It's
important for an open community to make it easy for anyone to build the
project and to be able to work like the developers of the project so
that they can contribute high quality patches, including JUnit tests for
their additional capabilities. Thanks for sharing your experience so
that others can reuse it. Probably this information should go in a wiki
so that it's easy to find and easy to update as things change...
> 2b) org.eclipse.wst
> 2c) org.eclipse.jst
> 2d) org.eclipse.jpt
> name=WTP
> id=org.eclipse.wst
> name=Visual Editor
Re: Updated patched VE for 3.3/Europa [message #141067 is a reply to message #141045] |
Tue, 25 September 2007 06:31 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Originally posted by: steinbach.gmx-topmail.de
Hello Erik,
> Here is the link again where you can find my (non-official) version.
> http://www.ehecht.com/eclipse_ve/ve.html
Which kind of the wtp package should be installed to have "jem"
in my windows installation of Europe?
the "Web Tools Platform All-In-One Packages" (~260M win)
-> wtp-all-in-one-sdk-R-2.0-200706260303-win32.zip
the "Web Tools Platform Complete" (~37M win)
-> wtp-R-2.0-200706260303.zip
or the "Web Standard Tools" (~18M win)
-> wtp-wst-R-2.0-200706260303.zip
Thomas
Re: Updated patched VE for 3.3/Europa [message #141145 is a reply to message #140822] |
Mon, 24 September 2007 00:04 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Philippe Ombredanne![Friend of Eclipse Friend](/donate/web-api/friends_decorator.php?email=pombredanne%40nexb.com) Messages: 386 Registered: July 2009 |
"Chris Dolan" <christopher_dolan@avid.com> wrote in message
news:155712966.30271190320497180.JavaMail.root@cp9.dzone.com...
> 2b) org.eclipse.wst
> 2c) org.eclipse.jst
> 2d) org.eclipse.jpt
> name=WTP
> id=org.eclipse.wst
> 4a) Go to
> name=Visual Editor
Hey that is a cool step by step guide :-)
Note:The .eclipseextension can be empty. the content does not matter mostly.
Could you do something for all of us?
Add those steps and instructions to that wiki page:
http://wiki.eclipse.org/VE/Installing
Then as soon as we have anofficial build we can update it :-)
Thanks!
Re: Updated patched VE for 3.3/Europa [message #141195 is a reply to message #140822] |
Wed, 26 September 2007 23:34 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Chris I added you rinstructions to that wiki page:
Thanks again!
All feel free to edit the page as needed if the step do not work for you.
Cheers, Philippe
http://www.nexb.com - http://eclipse.org/ve - http://eclipse.org/atf -
http://easyeclipse.org - http://phpeclipse.net
> 2b) org.eclipse.wst
> 2c) org.eclipse.jst
> 2d) org.eclipse.jpt
> name=WTP
> id=org.eclipse.wst
> 4a) Go to
> name=Visual Editor
Re: Updated patched VE for 3.3/Europa [message #141437 is a reply to message #140822] |
Tue, 02 October 2007 22:17 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Originally posted by: aslam.13thfloor.com
Thanks for the step by step but how do I accomplish step 1? When I go in,
I see no method to "fully uninstall" only disable.
Also can someone modify this step by step for a completely clean, new
install of Eclipse on OS X or Windows? What do I need to have on a virgin
install before starting all of this?
Aslam
P.S. Is the reason VE lost steam originally because there are other (maybe
commercial) WYSIWYG Swing editors that people are using more? If so what
are some of them?
Re: Updated patched VE for 3.3/Europa [message #141447 is a reply to message #141437] |
Tue, 02 October 2007 22:54 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Originally posted by: richkulp.us.NO_SPAM.ibm.com
Full uninstall will only be available if you used the update manager to
install and HAD NOT used -clean option. If you used -clean or did not
use the update manager then you need to do it by hand. You need to
delete the features and plugins and run -clean.
> in, I see no method to "fully uninstall" only disable.
> virgin install before starting all of this?
> Aslam
> (maybe commercial) WYSIWYG Swing editors that people are using more? If
> so what are some of them?
Rich Kulp
Re: Updated patched VE for 3.3/Europa [message #142237 is a reply to message #140822] |
Tue, 23 October 2007 18:50 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) |
Originally posted by: njagan.gmail.com
Hi Chris,
Thanks for the detailed instructions. I had spent more than a week and
was really going totally crazy with VE & Europa. Your article really
helped me immensely.
Thanks again!
Cheers!!!
Re: Updated patched VE for 3.3/Europa [message #616574 is a reply to message #140726] |
Thu, 20 September 2007 16:40 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) |
Ed Merks![Friend of Eclipse Friend](/donate/web-api/friends_decorator.php?email=ed.merks%40gmail.com) Messages: 33174 Registered: July 2009 |
Chris,
Chris Dolan wrote:
> Philippe,
> * unpacked the .zip
> * restarted
> Any ideas?
Ed Merks
Re: Updated patched VE for 3.3/Europa [message #616578 is a reply to message #140790] |
Thu, 20 September 2007 18:45 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) |
Chris,
Chris Dolan wrote:
> > Chris,
> > eclipse.exe -clean
> > run with -clean
> > might be failing
Ed Merks
Re: Updated patched VE for 3.3/Europa [message #616580 is a reply to message #140800] |
Thu, 20 September 2007 20:34 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) |
Junior Member |
2b) org.eclipse.wst
2c) org.eclipse.jst
2d) org.eclipse.jpt
name=WTP
id=org.eclipse.wst
name=Visual Editor
Re: Updated patched VE for 3.3/Europa [message #616584 is a reply to message #140822] |
Fri, 21 September 2007 12:45 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) |
Chris,
> 2b) org.eclipse.wst
> 2c) org.eclipse.jst
> 2d) org.eclipse.jpt
> name=WTP
> id=org.eclipse.wst
> name=Visual Editor
Ed Merks
Re: Updated patched VE for 3.3/Europa [message #616609 is a reply to message #140822] |
Mon, 24 September 2007 00:04 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) |
> 2b) org.eclipse.wst
> 2c) org.eclipse.jst
> 2d) org.eclipse.jpt
> name=WTP
> id=org.eclipse.wst
> 4a) Go to
> name=Visual Editor
Thanks!
Re: Updated patched VE for 3.3/Europa [message #616614 is a reply to message #140822] |
Wed, 26 September 2007 23:34 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) |
Thanks again!
Cheers, Philippe
> 2b) org.eclipse.wst
> 2c) org.eclipse.jst
> 2d) org.eclipse.jpt
> name=WTP
> id=org.eclipse.wst
> 4a) Go to
> name=Visual Editor
Re: Updated patched VE for 3.3/Europa [message #616637 is a reply to message #140822] |
Tue, 02 October 2007 22:17 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) |
Aslam
are some of them?
Re: Updated patched VE for 3.3/Europa [message #616638 is a reply to message #141437] |
Tue, 02 October 2007 22:54 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) |
> Aslam
Rich Kulp
Re: Updated patched VE for 3.3/Europa [message #616641 is a reply to message #141455] |
Wed, 03 October 2007 07:32 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) |
Konstantin Scheglov![Friend of Eclipse Friend](/donate/web-api/friends_decorator.php?email=Konstantin.Scheglov%40gmail.com) Messages: 555 Registered: July 2009 |
Philippe Ombredanne wrote:
> For the future of VE there are several possibilities:
> 1/ focus exclusively on SWT and do it extremely well
> 2/ continue to provide a more generic editing framework, and supporting
> visual editing of non-java target such as GWT, HTML, Groovy, EXSWT, etc.
GWT is Java target.
Konstantin Scheglov,
Google, Inc.
Re: Updated patched VE for 3.3/Europa [message #616760 is a reply to message #141640] |
Thu, 11 October 2007 14:09 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) |
>> GWT is Java target.
> True, but the rendering is not Java so that would mean some other
> techniques?
> Or not?
"Or not." :-)
You have classes with Java code and special methods with JavaScript code.
You can use special ClassLoader to (re)implement these methods to
execute this JavaScript code in browser. After this you can just execute
these classes in normal JVM. How do you think this is done in GWT hosted
mode or in GWT Designer?
Google, Inc.
Re: Updated patched VE for 3.3/Europa [message #616797 is a reply to message #140822] |
Hi Chris,
Thanks again!
Cheers!!!
Current Time: Sun Jul 07 08:06:30 GMT 2024
Powered by FUDForum. Page generated in 0.09330 seconds
