Home » Eclipse Projects » Eclipse Platform » Converting a View to an Editor
Converting a View to an Editor [message #139869] Sun, 05 October 2003 21:34 Go to next message
I've successfully implemented/extended the table editor described in the
"Building and delivering a table editor with SWT/JFace" Eclipse Corner
article. Unfortunately, I need this editor to appear in the 'center'
frame of the Eclipse window. This appears to be reserved for Editors.
I've tried to convert the View to an Editor with no luck.
Can someone outline the steps necessary to make such a conversion?
-Mitch
FWIW, my approach was to do the following:
o Create a new Editor plugin project using PDE (based on the XML editor
example).
o Delete all XML Editor classes except for the class that extends
TextEditor.
o Added/Implemented creatPartControl() and copied code from the Table
Editor example.
o All compiles fine, but I can't bring up the table editor.
o I mapped the file extension of '.pgd'. But opening a file of that type
from the navigator opens a standard text editor.
Re: Converting a View to an Editor [message #139903 is a reply to message #139869] Sun, 05 October 2003 22:32 Go to previous messageGo to next message
I am no specialist on editors but I think you need to use a different file
extension,as thats what Eclipse platform looks for when a editor is
invoked.
My reason for saying this is that when I created my javaeditor I had to
use a different file extension to make the platform know that it is my
editor not the Eclipse javaEditor.
You can get this done (i think) by specifying a different file extension
in the plugin.xml file for your editor.
I hope this helps.
Syed
> -Mitch
> example).
> TextEditor.
> Editor example.
Re: Converting a View to an Editor [message #140143 is a reply to message #139903] Mon, 06 October 2003 10:17 Go to previous message
Brilliant. Thank you.
I'm building a "Posting Grid", so a .pgd extension seemed natural. Just
my luck that I would choose an unacceptable extension.
Works now.
-Mitch
> invoked.
> I hope this helps.
> Syed
> > Thanks,
> > -Mitch
> > example).
> > TextEditor.
> > Editor example.
Previous Topic:MessageBox from Plugin class?
Next Topic:Action set vanished
Current Time: Wed Oct 22 03:55:45 EDT 2025
Powered by FUDForum. Page generated in 0.07193 seconds
