| checking in testsuite under CVS [message #139571] |
Wed, 14 January 2009 17:12  |
I have a Tptp test suite that I would like to check in so that our build
team can run the suite.
Do I need to add the entire workspace or is there some way to just check in
the test project.
I'm running the testsuite via ant.
thanks,
matt
| Re: checking in testsuite under CVS [message #139721 is a reply to message #139706] |
Tue, 27 January 2009 06:54  |
Hi Matt,
Yes, some of the test suites may be empty, depending if the test plug-in
owner has recorder/generated test cases. Sometimes, test plug-in owners
will create empty test suites for testers/developers to add tests cases.
Since ASF launches a headless instance of Eclipse to run the test
suites, you always need to specify the workspace.
For a sample, see our ASF tests in our CVS repository:
/test-results/test/org.eclipse.hyades.test.core.services.tes ts/resources/Ant/build.xml
Paul
"matt murphy" <murphy@coherentlogix.com> wrote in message
news:gllknv$5ou$1@build.eclipse.org...
> Hi Paul,
> I've checked out the tptp test suite reference in the document. I've
> looked at a couple gui test files and they are empty. There only appears
> to be junit tests. Is this correct? The test suite does not reference any
> other test assets.
> I've included an xml file I'm using to run my tests. I've been trying
> various combinations of properties to run the test suite without having to
> specify workspace. Do you know someway to run via withonly the project?
> thanks,
> matt
> "Paul Slauenwhite" <paules@ca.ibm.com> wrote in message
> news:gl4cg2$qm4$1@build.eclipse.org...
>> Hi Matt,
>> If the test suite does not reference any other test assets (e.g. other
>> test suites) or other test assets referencing the test suite (e.g. test
>> logs), the test suite does not need to reside in any specific directory
>> in
>> particular. Otherwise, the test suite will have to reside in the same
>> directory within a Java or Plug-in project. We (TPTP) check in our
>> Plug-in
>> projects to CVS and have our build machine extract these plug-ins and
>> execute their tests. For more information, see:
>> http://www.eclipse.org/tptp/home/documents/process/TPTP_Test ing_Strategy.html
>> Paul
>> news:gklo16$doo$1@build.eclipse.org...
>>> Hi,
>>> in the test project.
>>> thanks,
>>> matt
FUDForum. Page generated in 0.03289 seconds
