JRE [message #139031] |
Mon, 16 July 2007 07:31  |
Originally posted by: kristine.johansen.bahn.de
When downloading the latest version of the Visual Editor the following is
stated:
"JRE must be version 1.4.2 or greater for BeanInfo of SWT to work
correctly."
I suppose this applies to the design environment, i.e. the user working
with VE to design an SWT GUI needs to have at least JRE 1.4.2 for VE to
work correctly. Does it also apply to the runtime environment of the SWT
GUI created with VE?
Re: JRE [message #139105 is a reply to message #139066] |
Tue, 17 July 2007 11:46  |
Originally posted by: richkulp.us.NO_SPAM.ibm.com
It is not used in the actual generated code. But it is used by the
remote vm that is used to emulate/execute pieces of your code to display
the results in the VE's editor pane.
kjo wrote:
> Thanks for your reply!
> Do you know under which circumstances BeanInfo is used in the generated
> SWT code, so that it will not work with a JRE < 1.4.2?
Re: JRE [message #616275 is a reply to message #139031] |
Mon, 16 July 2007 12:41  |
It applies to runtime environment too.
> is stated:
> correctly."
Re: JRE [message #616277 is a reply to message #139043] |
Tue, 17 July 2007 06:59  |
Re: JRE [message #616282 is a reply to message #139066] |
FUDForum. Page generated in 0.03579 seconds
