Re: CDT Draft Plans V1 and V2 Posted [message #12841 is a reply to message #12762] |
Fri, 25 January 2002 06:53 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Originally posted by: johan.nosp.m.appeal.se
The plan talks about only testing with Motif builds. As support for
GTK+ is one of the reasons I want to use 2.0, I would really appreciate
having you testing with GTK+.
Especially since Linux seems to be your #1 target platform, focusing
mainly on a seldom used (on Linux) widget set like Motif seems kind of
backwards to me.
Regards //Johan
Robert Cecco wrote:
> Draft plans for CDT Project V1.0 and V2.0 have been posted here
> http://64.38.235.23/tools/cdt/downloads/
> Please send your comments concerning these plans to cdt-dev@eclipse.org
> Rob Cecco
Re: CDT Draft Plans V1 and V2 Posted [message #14011 is a reply to message #12841] |
Fri, 25 January 2002 10:09 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Originally posted by: s.schaefer.schaefer-edv.de
I have the same opinion.
"Johan Walles" <johan.nosp@m.appeal.se> schrieb im Newsbeitrag
news:3C5100CF.2040907@m.appeal.se...
> backwards to me.
> Regards //Johan
> > Thanks,
> > Rob Cecco
Re: CDT Draft Plans V1 and V2 Posted [message #14042 is a reply to message #12841] |
Fri, 25 January 2002 14:56 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
C4Eclipse Team![Friend of Eclipse Friend](/donate/web-api/friends_decorator.php?email=eclipsc%40ca.ibm.com) Messages: 65 Registered: July 2009 |
Member |
We agree that the GTK support is important, but our decision to focus our
testing on the Motif version, is based on a few factors:
1. The Eclipse R2.0 plans says the following:
"Note that the Linux GTK configuration is considered early access for the 2.0
release; it will be tested, but it is known in advance that it will not be of
product quality in this release."
2. We have limited testing resource and testing our code against a stable Motif
version would probably bear more fruit than testing on an potentially unstable
GTK version (while testing with the GTK version we would need to do more
investigation to determine if a UI or performance problem was our bug or the
GTK's).
All that being said, we will not be ignoring the GTK version. We will be doing
some basic testing on the latest versions, and will fix bugs reported by others
using it.
Thanks...
Jeff Turnham
"Johan Walles" <johan.nosp@m.appeal.se> wrote in message
> backwards to me.
> Regards //Johan
> > Thanks,
> > Rob Cecco
Re: CDT Draft Plans V1 and V2 Posted [message #14058 is a reply to message #14042] |
Fri, 25 January 2002 15:13 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) |
Good enough for me. Good to hear that you are aware of that this is an
issue!
Cheers //Johan
Jeff Turnham wrote:
> GTK's).
> using it.
> Thanks...
> Jeff Turnham
>>backwards to me.
>> Regards //Johan
>>>Thanks,
>>>Rob Cecco
FUDForum. Page generated in 0.07937 seconds
