Home » Archived » Test and Performance Tools Platform (TPTP) » Entry Point Not Found
Entry Point Not Found [message #12720] Thu, 31 March 2005 02:17 Go to next message
When trying to profile a simple HelloWorld application (eg.
System.out.println("Hello World"); ) I get the following error 4 times:
java.exe - Entry Point Not Found
The procedure entry point CM_Get_DevNode_Status_Ex could not be located
in the dynamic link library SETUPAPI.DLL
I have setup RAServer to use C:\j2sdk1.4.2_06\jre\bin\java.exe and the
default VM is set to the same.
Using Hyades 3.0.2_20050225_1641
Re: Entry Point Not Found [message #13628 is a reply to message #12720] Tue, 05 April 2005 11:42 Go to previous message
I have added this to bug tracker. see
https://bugs.eclipse.org/bugs/show_bug.cgi?id=90310
Previous Topic:cant find org.eclipse.tptp.platform.log.views.internal.LogViewsPlugin
Next Topic:Can't find plugin org.eclipse.hyades.logging.adapter.config
Current Time: Wed Apr 16 03:54:16 EDT 2025
Powered by FUDForum. Page generated in 0.03433 seconds
