run Validation from custom Menu [message #138240] |
Thu, 21 June 2007 06:10  |
I have a Custom Menu in my GMF diagram with a button "myValidate". I
want this button to run the Validation of the diagram (the same action
as in "Diagram/Validate" menu).
The problem is that I don't know how to access this IAction from the
Class that handels my menu actions.
How can I access this action in order to run it ?
thanks,
regards.
Tex.
Re: run Validation from custom Menu [message #139932 is a reply to message #139849] |
Wed, 27 June 2007 08:01   |
Yes there is a static method
runValidation(View view)
But then how can I get tje "view" parameter from a IEditorPart or a
DiagramEditor
thx ,
Tex
Dmitry Stadnik wrote:
> There should be a static method in ValidateAction class to run
> validation; I think it's not necessary to instantiate it.
> Tex Twil wrote:
>> ok,
>> I've just found the solution which is quite .... easy :)
>> (editor is a IEditorPart)
>> XXX.diagram.part.ValidateAction validateAction;
>> IWorkbenchPartDescriptor partDescriptor =
>> new WorkbenchPartDescriptor(
>> editor.getSite().getId(),
>> editor.getClass(),
>> editor.getSite().getPage());
>> validateAction = new ValidateAction(partDescriptor);
>> validateAction.run();
>> cheers,
>> Tex.
>> Tex Twil wrote:
>>> Yes,
>>> it's in package XXX.diagram.part.
>>> I don't know where to get the parameter for the constructor:
>>> ValidateAction(IWorkbenchPartDescriptor workbenchPartDescriptor)
>>> Tex.
>>>> Now ValidateAction has it's own file.
>>>> Tex Twil wrote:
>>>>> Hi,
>>>>> yes that's what I found here :
>>>>> http://dev.eclipse.org/newslists/news.eclipse.modeling.gmf/m sg06307.html
>>>>> but in my XXXValidationProvider class I don't have the static class
>>>>> ValidateAction class.
>>>>> Tex.
>>>>> Khai M Nguyen wrote:
>>>>>> In your generated ...diagram.providers package you should have a
>>>>>> XXXValidationProvider class with a static ValidateAction class
>>>>>> defined in it. From your menu item you can call the static method
>>>>>> ValidateAction.runValidation(view).
>>>>>> -- Khai --
>>>>>> Tex Twil wrote:
>>>>>>> Hello,
>>>>>>> "myValidate". I want this button to run the Validation of the
>>>>>>> diagram (the same action as in "Diagram/Validate" menu).
>>>>>>> the Class that handels my menu actions.
>>>>>>> thanks,
>>>>>>> regards.
>>>>>>> Tex.
Re: run Validation from custom Menu [message #139964 is a reply to message #139932] |
Wed, 27 June 2007 08:30   |
Originally posted by: 5d5.mail.ru
View is a model of editpart; you may use diagram editpart or editparts
selected on diagram.
> DiagramEditor
> thx ,
> Tex
>> Tex Twil wrote:
>>> ok,
>>> editor.getClass(),
>>> cheers,
>>> Tex.
>>> Tex Twil wrote:
>>>> Yes,
>>>> Tex.
>>>>> Tex Twil wrote:
>>>>>> Hi,
>>>>>> class ValidateAction class.
>>>>>> Tex.
>>>>>>> method ValidateAction.runValidation(view).
>>>>>>> -- Khai --
>>>>>>> Tex Twil wrote:
>>>>>>>> Hello,
>>>>>>>> thanks,
>>>>>>>> regards.
>>>>>>>> Tex.
Re: run Validation from custom Menu [message #139991 is a reply to message #139964] |
Wed, 27 June 2007 09:24  |
Ok, thank you very much. This helped me also for my other post about
validating while saving the diagram.
thx,
Tex.
>> DiagramEditor
>> thx ,
>> Tex
>>> Tex Twil wrote:
>>>> ok,
>>>> editor.getClass(),
>>>> cheers,
>>>> Tex.
>>>> Tex Twil wrote:
>>>>> Yes,
>>>>> Tex.
>>>>>> Tex Twil wrote:
>>>>>>> Hi,
>>>>>>> Tex.
>>>>>>>> -- Khai --
>>>>>>>> Tex Twil wrote:
>>>>>>>>> Hello,
>>>>>>>>> from the Class that handels my menu actions.
>>>>>>>>> thanks,
>>>>>>>>> regards.
>>>>>>>>> Tex.
FUDForum. Page generated in 0.31010 seconds
