Where do jars with db drivers need to go for BIRT viewer in Tomcat [message #138028] |
Thu, 02 March 2006 13:16 ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Originally posted by: mslists.lexi.com
I have the BRT view installed as a web app in Tomcat and the parameter
dialog comes up ok, but no data is returned in the report. I'm assuming
that it cannot connect to the database. Where should the jar files
containing the jdbc drivers go?
Re: Where do jars with db drivers need to go for BIRT viewer in Tomcat [message #138161 is a reply to message #138028] |
Thu, 02 March 2006 15:23 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
C:\Program Files\Apache Software Foundation\Tomcat
5.5\webapps\birt\plugins\org.eclipse.birt.report.data.oda.jd bc\drivers
Re: Where do jars with db drivers need to go for BIRT viewer in Tomcat [message #138361 is a reply to message #138161] |
Thu, 02 March 2006 17:37 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Running on unix, and I have put the jar everywhere I can think of:
tomcat/common/lib
tomcat/shared/lib
tomcat/webapps/birt-viewer/WEB-INF/lib
tomcat/webapps/birt-viewer/plugins/org.eclipse.birt.report.d ata.oda.jdbc/drivers
tomcat/webapps/birt-viewer/plugins/org.eclipse.birt.report.d ata.oda.jdbc/lib
tpmcat/webapps/birt-viewer/plugins/org.eclipse.birt.report.d ata.oda.jdbc
still no data appearing in the report...
Re: Where do jars with db drivers need to go for BIRT viewer in Tomcat [message #138373 is a reply to message #138361] |
Thu, 02 March 2006 18:04 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
> tomcat/common/lib
> tomcat/shared/lib
Probably you didn't bind report parameters to dataset parameters.
Re: Where do jars with db drivers need to go for BIRT viewer in Tomcat [message #138813 is a reply to message #138373] |
Fri, 03 March 2006 11:50 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Vladimir wrote:
>>tomcat/common/lib
>>tomcat/shared/lib
Nope; forgot to say that the report runs fine inside eclipse. The params are getting bound there...
Re: Where do jars with db drivers need to go for BIRT viewer in Tomcat [message #138931 is a reply to message #138813] |
Fri, 03 March 2006 15:57 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
I know one more situation when it happen.
If you use firefox 1.5 and birt 2.0 release.
Newer version of the birt fixed problem with Firefox.
Anyway good idea to check out log file.
Location of the log file defined in web.xml
Re: Where do jars with db drivers need to go for BIRT viewer in Tomcat [message #139574 is a reply to message #138931] |
Mon, 06 March 2006 13:57 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
I'm using 2.0.0 or the report framework and 2.0.1 of the runtime with firefox; guess i need newer...
FUDForum. Page generated in 0.04305 seconds
