| Home » Language IDEs » ServerTools (WTP) » Eclipse not accepting taglib tag in web.xml
 Goto Forum:|
| Eclipse not accepting taglib tag in web.xml [message #137890] | Fri, 09 September 2005 13:40  |  |
| Eclipse User  |  |  |  |  | Originally posted by: neil.JAMMConsulting.com
 Hello:
 I am converting an existing struts based web app into an Eclipse WTP
 project.
 Eclipse does not like my web.xml, it gives me this error:
 cvc-complex-type.2.4.a: Invalid content was found starting with element
 'taglib'.
 One of '{"http://java.sun.com/xml/ns/j2ee":description,
 "http://java.sun.com/xml/ns/j2ee":display-name,
 "http://java.sun.com/xml/ns/j2ee":icon,
 "http://java.sun.com/xml/ns/j2ee":distributable,
 "http://java.sun.com/xml/ns/j2ee":context-param,
 "http://java.sun.com/xml/ns/j2ee":filter,
 "http://java.sun.com/xml/ns/j2ee":filter-mapping,
 "http://java.sun.com/xml/ns/j2ee":listener,
 "http://java.sun.com/xml/ns/j2ee":servlet,
 "http://java.sun.com/xml/ns/j2ee":servlet-mapping,
 "http://java.sun.com/xml/ns/j2ee":session-config,
 "http://java.sun.com/xml/ns/j2ee":mime-mapping,
 "http://java.sun.com/xml/ns/j2ee":welcome-file-list,
 "http://java.sun.com/xml/ns/j2ee":error-page,
 "http://java.sun.com/xml/ns/j2ee":jsp-config,
 "http://java.sun.com/xml/ns/j2ee":security-constraint,
 "http://java.sun.com/xml/ns/j2ee":login-config,
 "http://java.sun.com/xml/ns/j2ee":security-role,
 "http://java.sun.com/xml/ns/j2ee":env-entry,
 "http://java.sun.com/xml/ns/j2ee":ejb-ref,
 "http://java.sun.com/xml/ns/j2ee":ejb-local-ref,
 "http://java.sun.com/xml/ns/j2ee":service-ref,
 "http://java.sun.com/xml/ns/j2ee":resource-ref,
 "http://java.sun.com/xml/ns/j2ee":resource-env-ref,
 "http://java.sun.com/xml/ns/j2ee":message-destination-ref,
 "http://java.sun.com/xml/ns/j2ee":message-destination,
 "http://java.sun.com/xml/ns/j2ee":locale-encoding-mapping-list}' is
 expected.
 Here is my web.xml:
 <web-app xmlns="http://java.sun.com/xml/ns/j2ee"
 xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"
 xsi:schemaLocation="http://java.sun.com/xml/ns/j2ee
 http://java.sun.com/xml/ns/j2ee/web-app_2_4.xsd"
 version="2.4">
 <!-- Standard Action Servlet Configuration (with debugging) -->
 <servlet>
 <servlet-name>action</servlet-name>
 <servlet-class>org.apache.struts.action.ActionServlet</servlet-class >
 <init-param>
 <param-name>config</param-name>
 <param-value>/WEB-INF/struts-config.xml</param-value>
 </init-param>
 <init-param>
 <param-name>debug</param-name>
 <param-value>0</param-value>
 </init-param>
 <init-param>
 <param-name>detail</param-name>
 </init-param>
 <load-on-startup>2</load-on-startup>
 </servlet>
 <!-- Standard Action Servlet Mapping -->
 <servlet-mapping>
 <url-pattern>*.do</url-pattern>
 </servlet-mapping>
 <!-- The Welcome File List -->
 <welcome-file-list>
 <welcome-file>index.jsp</welcome-file>
 </welcome-file-list>
 <!-- Application wide error pages -->
 <error-page>
 <exception-type>java.lang.Throwable</exception-type>
 <location>/error.do</location>
 </error-page>
 <!-- Struts Tag Library Descriptors -->
 <taglib>
 <taglib-uri>/tags/struts-bean</taglib-uri>
 <taglib-location>/WEB-INF/struts-bean.tld</taglib-location >
 </taglib>
 <taglib>
 <taglib-uri>/tags/struts-html</taglib-uri>
 <taglib-location>/WEB-INF/struts-html.tld</taglib-location >
 </taglib>
 <taglib>
 <taglib-uri>/tags/struts-logic</taglib-uri>
 <taglib-location>/WEB-INF/struts-logic.tld</taglib-location >
 </taglib>
 <taglib>
 <taglib-uri>/tags/struts-nested</taglib-uri>
 <taglib-location>/WEB-INF/struts-nested.tld</taglib-location >
 </taglib>
 <taglib>
 <taglib-uri>/tags/struts-tiles</taglib-uri>
 <taglib-location>/WEB-INF/struts-tiles.tld</taglib-location >
 </taglib>
 <!-- Do not allow users to load jsps directly -->
 <security-constraint>
 <web-resource-collection>
 <web-resource-name>no_access</web-resource-name>
 <url-pattern>*.jsp</url-pattern>
 </web-resource-collection>
 <auth-constraint/>
 </security-constraint>
 </web-app>
 Any ideas why this error is occurring?
 Neil
 Neil Aggarwal, JAMM Consulting, (214)986-3533, www.JAMMConsulting.com
 FREE! Valuable info on how your business can reduce operating costs by
 17% or more in 6 months or less! http://newsletter.JAMMConsulting.com
| Re: Eclipse not accepting taglib tag in web.xml [message #137902 is a reply to message #137890] | Fri, 09 September 2005 14:00   |  |
| Eclipse User  |  |  |  |  | This web.xml would probably be valid for Servlet 2.3, but with Servlet 2.4, the schema requires that <taglib> elements be children of a
 <jsp-config> element.
 Larry
 Neil Aggarwal wrote:
 > Hello:
 > project.
 > 'taglib'.
 > expected.
 > Here is my web.xml:
 >     version="2.4">
 > <servlet>
 >     <init-param>
 >     </init-param>
 >     <init-param>
 >     </init-param>
 >     <init-param>
 >     </init-param>
 > </servlet>
 > <servlet-mapping>
 > </servlet-mapping>
 > <welcome-file-list>
 > <error-page>
 > </error-page>
 > <taglib>
 > </taglib>
 > <taglib>
 > </taglib>
 > <taglib>
 > </taglib>
 > <taglib>
 > </taglib>
 > <taglib>
 > </taglib>
 >     <auth-constraint/>
 > </web-app>
 >      Neil
| Re: Eclipse not accepting taglib tag in web.xml [message #138296 is a reply to message #137997] | Mon, 12 September 2005 10:47  |  |
| Eclipse User  |  |  |  |  | Larry is describing some additional metadata that tracks the "module" version, and should be changed as well.  The .wtpmodules file uses the
 <module-type module-type-id="jst.web">
 <version>2.3</version> attribute, make sure you change this as
 well.
 The servlet schema didn't change too much between these versions, so you
 should be fine....
 - Chuck
 Larry Isaacs <Larry.Isaacs@sas.com> wrote in
 news:dft26d$lus$1@news.eclipse.org:
 > If you only change the web.xml, only the server will think the webapp
 > is 2.3.  WebTools will still think it's 2.4 since that is how it was
 > created.  WebTools wouldn't let you test it with a Tomcat 4.1 server.
 > When you create a Dynamic Web Application, make sure the Advanced
 > section is displayed.  It is there that you can select the module's
 > J2EE version.  You may want to create a new 2.3 Dynamic Web
 > Application and copy your current content over.
 > You could compare ".*" files between the two and try to manually
 > change your current project to 2.3.  However, I don't know if that
 > might make the project inconsistent with cached information that would
 > lead to erroneous behavior.
 > Larry
 Current Time: Fri Oct 31 02:07:21 EDT 2025
 Powered by FUDForum . Page generated in 0.04377 seconds |
